Hey everyone!
I was searching for answers in this forum and else, but was not able to find any. At least not any which were able to help me out. If I have overseen something, I would appreciate it if you just send a link. Thank you!
My Problem:
For at least one day I am now trying to get this right. Until now I was always working with the root user. In the beginning of the set-up-process I did not think much about it. Now I have learned a lot, set everything up so far, the only thing which is left to do is make the other users work... which is more complicated than I thought it was.
Permissions of the .ssh directory and downwards are set and I am sure they are ok.
Root login is no problem, I even changed the public key, just to verify. It is working fine.
The other User Leon is not working. Everytime I try to connect with it gives me: , and on the other side in the .
I created a new account and inserted the working public key of the root account. Does not work either.
What else could it be if it is not the public key or permissions? Should I just reset and start from scratch?
I am not sure what else you need for analyzing the problem. I would even give someone remote access to my machine just to solve the problem if that's easier and faster!
Thank you in advance!
My Problem:
ssh -p 52739 Leon@192.168.178.97
Permission denied (publickey)
/var/log/auth.log the error is Code:
Oct 30 02:13:26 freenas sshd[76019]: Connection closed by authenticating user Leon 192.168.178.92 port 51976 [preauth]
