AMD FX-8120 (I had this already, I know it's overkill. Currently underclocked to ~2.4ghz, slightly undervoltaged and running AMD Cool n' Quiet)
ASUS M5A97 Motherboard
16GB DDR3 ECC Memory
4x 1.5TB WD Drives RaidZ1
1x 2TB WD Drive Striped
On my last scrub this error popped up on a single ZFS drive. This drive does not have overly important data, but it will take some time to restore if I need to wipe the pool. I was hoping there was another way or that you guys had some suggestions.
A couple of days ago I upgrade to ECC Ram. I ran a 1-pass memtest which passed. I know you need to do more than 1 pass, and I will do that overnight when I get a chance.
Running
zpool status -v it tells me:
Running
smartctl -a /dev/ada0-5 all return passes
And all my data is obtainable, usable and mountable since it is metadata that seems to have failed.
Lastly I am getting a separate issue on my 4 1.5TB drives. But I do not think it is too bad (Please correct me if I am wrong).
But I get:
only at boot and it never shows up again. Maybe when the disks are being initialized, or if they go to sleep this error pops up the one time?
Also been reading through:
https://forums.freenas.org/index.php?threads/permanent-errors-in-zfs-pool.14453/
Performance wise, though, this thing has been and still is running like a champ!
Running
Password: pool: FTPData state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 0 in 3h22m with 1 errors on Sun Jan 31 03:22:22 2016 config: NAME STATE READ WRITE CKSUM FTPData ONLINE 0 0 0 gptid/a84af760-b4a9-11e5-820a-c86000da62cb ONLINE 0 0 0 errors: Permanent errors have been detected in the following files: <metadata>:<0x1e>
Running
But I get:
ahcichx Timeout on slot X port 0
