OS is hung .(swap_pager: indefinite wait buffer)
T.shiina
OS is hung .(Adaptec 5045 RAID5)
Operating system is hung.(FreeNAS-8.3.0BETA3)
Messages are kept displayed on the Display.
Power OFF/ON after the recovery, error log below have been printed to dmesg.
 aac0: COMMAND 0xffffff80003c6770 (TYPE 502) TIMEOUT AFTER 122 SECONDS
 aac0: WARNING! Controller is no longer running! code= 0xbc060100
 swap_pager: indefinite wait buffer: bufobj: 0, blkno: 12934, size: 24576
What should I do for relapse prevention is to?
  • HW_info.txt
T.shiina
Did the following things.
Has since passed 1 month, the same event is not occurring.
1. Check the backplane cable > no problem
2. adaptec driver upgrade > Driver: 2.4 - 1 (18284)
like do not support FreeBSD8.3 is aacraid_freebsd_b18668, aacraid_freebsd_b18284 is installed.
aacraid_freebsd_b18668-> readme.txt
-FreeBSD Drivers
o FreeBSD 7.4, 8.2
aacraid_freebsd_b18284-> readme.txt
-FreeBSD Drivers
o FreeBSD 7.3, 8.x
Also confirmed in these notices. Have reseated several times during boot, reboot also hang did not.
-aacraid_freebsd_b18284-> readme.txt
4.15 Failed Arrays under FreeBSD 8
If an array fails under FreeBSD 8 (including pulling a drive
from the array), the firmware may crash causing the system
to hang or reboot automatically
