Organizr install help with nginx reverse proxy
Zwck
Senior Member
if you have your reverse proxy running you just need to add a file in
/mnt/ssd/jails/{ReverseProxyJailName}/usr/local/etc/nginx/vhost
and add a configuration similar to this: file organizer.conf
server {
listen 192.168.0.99:80; #ip of your reverse proxy ip
server_name organizer.domainname.tld;
location / {
	return 301 https://$server_name$request_uri;
server {
listen 192.168.0.99:443 ssl;
	ssl_certificate /usr/local/etc/nginx/certs/CERT.pem;
	ssl_certificate_key /usr/local/etc/nginx/certs/KEY.key;
	ssl_prefer_server_ciphers On;
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
	ssl_ciphers ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:DHE-RSA-AES256-SHA;
	ssl_stapling on;
	#resolver 8.8.8.8 8.8.4.4 valid=300s; resolver_timeout 5s;
	ssl_stapling_verify on;
	ssl_trusted_certificate /usr/local/etc/nginx/certs/CERTS.pem;
	keepalive_timeout 180;
	#client_max_body_size 1024M;
	   location / {
	proxy_set_header Host			 $host;
	proxy_set_header X-Real-IP		$remote_addr;
	proxy_set_header X-Forwarded-For  $proxy_add_x_forwarded_for;
	proxy_set_header Upgrade $http_upgrade;
	proxy_set_header Connection "upgrade";
	proxy_set_header X-Forward-Proto http;
	proxy_set_header X-Nginx-Proxy true;
	proxy_http_version 1.1;
	proxy_redirect off;
	  proxy_pass http://redirectionip:3000; #where the redirection happens
at your router level you need to forward incoming traffic on port 80 to your reverse proxy
This is a configfile that works for me, you need to change some things for sure.
drkmachine
Neophyte
@Zwck thank you, however I do not have a vhost directory which I would assume would be setup in nginx to automatically include the organizr.conf that you posted. So should I add an include organizr.conf to my nginx.conf and if so where? Perhaps it is too early for me and/or not enough caffeine. Perhaps I should post up my config files for reference?
Zwck
Senior Member
Yeah, I was not sure if i had changed some stuff, i set this up quite some time ago. you have to do the following.
1. create the folder vhosts
2. edit nginx.conf in the /nginx folder
nginx.conf
user www;
worker_processes 1;
error_log /var/log/nginx/error.log;
events {
worker_connections 1024;
http {
include mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local]
"$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log;
sendfile on;
keepalive_timeout 65;
# Nginx cache configuration
proxy_cache_path /var/nginx/cache levels=1:2 keys_zone=my-cache:8m
max_size=1000m inactive=600m;
proxy_temp_path /var/nginx/cache/tmp;
proxy_cache_key "$scheme$host$request_uri";
gzip on;
server {
#listen 80;
server_name _; location /nginx_status { stub_status on; access_log off;
# redirect server error pages to the static page /50x.html
error_page 500 502 503 504 /50x.html; location = /50x.html { root
/usr/local/www/nginx-dist;
# proxy the PHP scripts to Apache listening on 127.0.0.1:8080y#
location ~ \.php$ {
proxy_pass http://127.0.0.1:8080;
include
/usr/local/etc/nginx/proxy.conf;
include /usr/local/etc/nginx/vhost/*;
now you can create a file in the vhost folder with the name
whatever.conf For each domain that you like to redirect make sure you create a new file in this folder.
if you also dont have a proxy.conf
proxy_buffering on;
proxy_redirect off;
client_max_body_size 10m;
client_body_buffer_size 128k;
proxy_connect_timeout 90;
proxy_send_timeout 90;
proxy_read_timeout 90;
proxy_buffers 100 8k;
add_header			  X-Cache $upstream_cache_status;
drkmachine
Neophyte
@Zwck ok, so here is where the confusion sets in again. Let me show you the configs I made per the thread I posted previously. With these my reverse proxy works.
nginx.conf
#user  nobody;
worker_processes  1;
# This default error log path is compiled-in to make sure configuration parsing
# errors are logged somewhere, especially during unattended boot when stderr
# isn't normally logged anywhere. This path will be touched on every nginx
# start regardless of error log location configured here. See
# https://trac.nginx.org/nginx/ticket/147 for more info.
#error_log  /var/log/nginx/error.log;
#pid		logs/nginx.pid;
events {
http {
	include	   mime.types;
	#log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
	#				  '$status $body_bytes_sent "$http_referer" '
	#				  '"$http_user_agent" "$http_x_forwarded_for"';
	#access_log  logs/access.log  main;
	sendfile		on;
	#tcp_nopush	 on;
	#keepalive_timeout  0;
	#gzip  on;
	server {
		listen 80;
		server_name theguild.myftp.org;
		return 301 https://$host$request_uri;
	server {
		listen	   443 ssl;
		server_name  example.com;
		include ssl_common.conf;
		include proxy_setup.conf;
		#charset koi8-r;
		#access_log  logs/host.access.log  main;
		location / {
			root   /usr/local/www/nginx;
			index  index.html index.htm index.php;
		#error_page  404			  /404.html;
			root   /usr/local/www/nginx-dist;
ssl_common
# Thanks to https://cipherli.st/ for providing a great reference! Please check out their
#site
# to make sure your SSL Configuration is up to date with current standards! Be aware that
#in this
# example we use a slightly liberal cipherlist to allow for older browsers on older
#devices, Eg.
# IE8, android 2.4, etc
# Enable Perfect Forward Secrecy (PFS)
ssl_prefer_server_ciphers on;
ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem;
# Disable SSLv2 and SSLv3 (BEAST and POODLE attacks)
# Enable our strong DH Key
ssl_dhparam /usr/local/etc/ssl/dhparams.pem;
# Cipher-list for PFS.
ssl_ciphers
"EECDH+AESGCM:EDH+AESGCM:ECDHE-RSA-AES128-GCM-SHA256:AES256+EECDH:DHE-RSA-AES128-GCM-SHA256:AES256+EDH:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:AES256-SHA:AES128-SHA:DES-CBC3-SHA:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
ssl_ecdh_curve secp384r1;
# Requires nginx >= 1.1.0
ssl_session_cache shared:SSL:10m;
ssl_session_tickets off;
# Requires nginx >= 1.5.9
ssl_stapling on;
# Requires nginx >= 1.3.7
# Requires nginx => 1.3.7
# HSTS Support
add_header Strict-Transport-Security "max-age=63072000;includeSubdomains; preload";
# These headers can break applications, be careful!
add_header X-Content-Type-Options nosniff;
Proxy_setup
	 location /sabnzbd {
	 proxy_pass http://192.168.1.4:9090;
	 proxy_redirect off;
	 location /sickrage {
	 proxy_pass http://192.168.1.6:8081;
	 proxy_redirect off;
	 location /couchpotato {
	 proxy_pass http://192.168.1.5:5050;
	 proxy_redirect off;
	 location /headphones {
	 proxy_pass http://192.168.1.7:8181;
	 proxy_redirect off;
	 location /ombi {
	 proxy_pass http://192.168.1.8:3579;
	 proxy_redirect off;
	 proxy_set_header X-Real_IP $remote_addr;
	 location /plexpy {
	 proxy_pass http://192.168.1.13:8181/plexpy/;
	 proxy_redirect off;
	 proxy_set_header X-Forwarded-Host $host:$server_port;
	 proxy_set_header X-Forwarded-Proto $scheme;
	 proxy_set_header X-Forwarded-Ssl on;
And even this setup is different. Appearantly there are a number of ways to accomplish the same thing. most of what I see is everything in 2 files. Perhaps I am over complicating it.
Zwck
Senior Member
i mean its all the same in the end, does your setup work ? if yes; good, if not then change it.
Overall what happens all the different files are "put" together in one file. (via the include functions)
drkmachine
Neophyte
currently my reverse proxy does work. However what I have is to access organizr i have to use example.com/organizr which really isn't that much of an inconvenience, but is it possible to set it so that I can access organizr by simply entering example.com? Trying to run everything on a single domain.
Zwck
Senior Member
when you navigate to example.com where do you land on?
you replace
location / {
in nginx.conf
with
location / {
	 proxy_pass http://192.168.1.ORGANIZER:PORT;
	 proxy_redirect off;
or similar
drkmachine
Neophyte
I land on the default nginx install success page. Editing the nginx.conf with that location I get
Performing sanity check on nginx configuration:
nginx: [emerg] "location" directive is not allowed here in /usr/local/etc/nginx/nginx.conf:70
nginx: configuration file /usr/local/etc/nginx/nginx.conf test failed
drkmachine
Neophyte
I got that worked out. Now to figure out the finer points of php I think since everything loads except my organizr settings page. Thank you @Zwck for all your help.
Zwck
Senior Member
glad you worked it out! cheers
what often helps is checking the browser console to see what is not working. websockets or similar. (lots of red)
Zwck
Senior Member
nope
