amurray
- Dec 14, 2013
Hello!
Right now in my test-build machine I have two zpools. The main one is six WD Reds arranged as three mirrored pairs, with a caching SSD for ZIL/L2ARC partitions. The secondary pool is three older SATA II drives in a stripe, used to store extra backups.
The six Reds are all connected to the motherboard's six on-board SATA ports (AMD 990X chipset) and the SSD and other three drives connected to a Highpoint 640L controller (4 ports, no hardware RAID shenanigans).
Everything is performing great, but I can't help but think that having all six Reds on one controller is a 'bad idea' and either way I'll need more ports to grow the Red pool (ie. add another mirror vdev.)
So, I have another Highpoint 640L SATA controller coming.
My question is what the optimal arrangement of controllers and drives would be?
I'm thinking:
Mirror 1-drive A -> controller 1
Mirror 1-drive B -> controller 2
Mirror 2-drive A -> controller 1
Mirror 2-drive B - > controller 2
Mirror 3-drive A -> controller 1
Mirror 3-drive B - > controller 2
...and put the SSD and the stripe's drives on the motherboard's controller? Or can/should I spread the stripe's drives out across the controllers as well? Will spreading a ZFS pool's disks across multiple controllers (of the same model) cause performance/reliability/timing issues?
What are the general rules for arranging disks across multiple (non-RAID) controllers for ZFS pools (or specific types of vdevs?) I haven't been able to find any ZFS/FreeNAS/FreeBSD specific requirements anywhere, so any advice/guidance would be appreciated.
Thanks!
AM
I'm thinking:
Thanks!
AM
