pincorrect
 - Jan 2, 2017
My first system is an ancient Mini-ITX system with just 2 (mirrored) drives. I can't count on it lasting too much longer, though it served me well. So I hope to move up to the latest and greatest with storage I won't run out of for a long time. And I'd like to explore a bunch of other uses beyond being a filer, including a transcoding project.
This is, I think, a straightforward SM X11 (Skylake) build that I hope does not stray too far off the beaten path. Any suggestions will be appreciated.
Chassis: Cooler Master HAF 932 http://www.coolermaster.com/case/full-tower/haf-932/ (I already had this from a workstation project I never started. It's a tower with 6 5.25 external bays in which I plan to put cages for 3.5" drives. Lots of fans and lots of perforated panels for airflow.)
Power Supply: Seasonic X-850 (Using jgreco's great Proper Power Supply Sizing Guidance post, I came up with a peak load of 651W and increased by 25% to pick the 850W model. However the Extreme Outer Vision calculator (http://outervision.com/power-supply-calculator) suggests a 288W peak load, recommends a 338W minimum size, and suggests buying a 500W power supply.)
Motherboard: Supermicro MBD-X11SSH-F
CPU: Xeon E3-1240 v5 (About $30 more than the 1230)
Ram: (From SM QVL for this MB) 4 x 16Gb (64Gb total) Samsung M391A1G43DB0-CPB
SSD: Intel SSD 600p Series 128G M.2 PCIe 3.0 x4 (At $65, the cheapest M.2 PCIe SSD on NewEgg. Wanted to save all the SATA ports for hard drives.) (This is a PCIe 3.0 x4 drive. The M.2 slot on the MB is x2. I think this will work, but will just get x2 speed, which doesn't really matter because it is just for booting.)
Hard drives: 8 x WD Red 4Tb 5400RPM (OK to buy all the same?)
Drive cages: either 3 Icy Dock cages that put 3 3.5” drives in 2 5.25” slots (horizontal) (http://www.newegg.com/Product/Produ...94052&cm_re=MB453IPF-B-_-17-994-052-_-Product), or 2 Icy Dock cages that put 5 3.5” drives in 3 5.25” slots (vertical) (http://www.newegg.com/Product/Produ...198058&cm_re=MB975SP-B-_-17-198-058-_-Product).
All advice and comments welcome. One additional question: can you recommend an appropriate UPS for this size machine?
