Opinions on drives being marked offline?
thonl
I've been running Freenas for a couple of years on some fairly old hardware
Intel DG965WH mobo with Core2 E6600 @ 2.4Ghz, 8GB non-ECC RAM, and 4 x 2TB Seagate ST2000DL003 (Green Barracuda) in Z2
The problem I run into is that occasionaly, ALWAYS induced by very heavy indexing load by the plex jail on the system(re-indexing MP3 or photos directory's that each contain 10's of thousands of individual files) I will get SMART errors indicating that a drive has gone offline.
If I power the box down completely and then back on, the drive(s) will be fine. A warm boot will not clear the error.
Wondering if anyone would have an opinion on possible culprits? non-ECC memory? replace SATA cables?
It is really more annoying that anything, but now that I am sharing the plex libraries with a couple of family members, I am trying to improve uptime if at all possible.
TIA!
Can you post the debug file for your box and the output of "smartctl -a /dev/XXX" for each applicable disk?
I won't lie to you, but don't be surprised if the end answer is "everything looks fine... don't use desktop grade boards for servers".
thonl
Yup - understood - Appreciate the feedback
[root@freenas] /# smartctl -a /dev/ada0
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p10 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda Green (AF)
Device Model: ST2000DL003-9VT166
Serial Number: 5YD86QM2
LU WWN Device Id: 5 000c50 03cebd142
Firmware Version: CC32
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5900 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Nov 10 12:53:43 2014 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 623) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 341) minutes.
Conveyance self-test routine
SCT capabilities: (0x30b7) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 116 099 006 Pre-fail Always - 115954608
3 Spin_Up_Time 0x0003 094 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 52
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 125171921
9 Power_On_Hours 0x0032 091 091 000 Old_age Always - 8180
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 52
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 097 000 Old_age Always - 4295032867
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 066 055 045 Old_age Always - 34 (Min/Max 33/34)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 48
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 52
194 Temperature_Celsius 0x0022 034 045 000 Old_age Always - 34 (0 23 0 0 0)
195 Hardware_ECC_Recovered 0x001a 032 010 000 Old_age Always - 115954608
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 233787954831347
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2004305407
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2651823775
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas] /# smartctl -a /dev/ada1
Serial Number: 5YD3DW9X
LU WWN Device Id: 5 000c50 036bee7e3
Local Time is: Mon Nov 10 12:53:46 2014 CST
been run.
data collection: ( 612) seconds.
command.
power-saving mode.
recommended polling time: ( 347) minutes.
1 Raw_Read_Error_Rate 0x000f 116 099 006 Pre-fail Always - 101932144
3 Spin_Up_Time 0x0003 094 090 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 119
7 Seek_Error_Rate 0x000f 085 060 030 Pre-fail Always - 338938059
9 Power_On_Hours 0x0032 068 068 000 Old_age Always - 28442
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 119
188 Command_Timeout 0x0032 100 097 000 Old_age Always - 4295032888
190 Airflow_Temperature_Cel 0x0022 064 052 045 Old_age Always - 36 (Min/Max 35/37)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 112
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 119
194 Temperature_Celsius 0x0022 036 048 000 Old_age Always - 36 (0 23 0 0 0)
195 Hardware_ECC_Recovered 0x001a 033 009 000 Old_age Always - 101932144
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 203061758816026
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 3612212886
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2194302150
No Errors Logged
# 1 Short offline Completed without error 00% 19434 -
# 2 Short offline Completed without error 00% 19433 -
# 3 Short offline Completed without error 00% 19432 -
# 4 Short offline Completed without error 00% 19432 -
# 5 Short offline Completed without error 00% 19430 -
# 6 Short offline Completed without error 00% 19416 -
# 7 Short offline Completed without error 00% 19416 -
# 8 Short offline Completed without error 00% 19415 -
# 9 Short offline Completed without error 00% 19414 -
#10 Short offline Completed without error 00% 19413 -
#11 Short offline Completed without error 00% 19412 -
#12 Short offline Completed without error 00% 19411 -
#13 Short offline Completed without error 00% 19410 -
#14 Short offline Completed without error 00% 19409 -
#15 Short offline Completed without error 00% 19408 -
#16 Short offline Completed without error 00% 19406 -
#17 Short offline Completed without error 00% 19405 -
#18 Short offline Completed without error 00% 19404 -
#19 Short offline Completed without error 00% 19403 -
#20 Short offline Completed without error 00% 19402 -
#21 Short offline Completed without error 00% 19401 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
thonl
[root@freenas] /# smartctl -a /dev/ada2
Serial Number: 6YD0PHJT
LU WWN Device Id: 5 000c50 03ced7180
Local Time is: Mon Nov 10 12:53:49 2014 CST
been run.
command.
power-saving mode.
recommended polling time: ( 338) minutes.
1 Raw_Read_Error_Rate 0x000f 116 099 006 Pre-fail Always - 105951216
3 Spin_Up_Time 0x0003 094 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 23
7 Seek_Error_Rate 0x000f 080 060 030 Pre-fail Always - 106693904
9 Power_On_Hours 0x0032 092 092 000 Old_age Always - 7796
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 23
187 Reported_Uncorrect 0x0032 095 095 000 Old_age Always - 5
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 11
190 Airflow_Temperature_Cel 0x0022 064 053 045 Old_age Always - 36 (Min/Max 35/37)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 22
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 23
194 Temperature_Celsius 0x0022 036 047 000 Old_age Always - 36 (0 9 0 0 0)
195 Hardware_ECC_Recovered 0x001a 033 012 000 Old_age Always - 105951216
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 272030343634548
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1000675420
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3577118874
ATA Error Count: 5
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 5 occurred at disk power-on lifetime: 7768 hours (323 days + 16 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
25 00 00 ff ff ff 4f 00 1d+11:45:28.280 READ DMA EXT
25 00 00 ff ff ff 4f 00 1d+11:45:24.841 READ DMA EXT
25 00 00 ff ff ff 4f 00 1d+11:45:21.373 READ DMA EXT
25 00 00 ff ff ff 4f 00 1d+11:45:17.919 READ DMA EXT
25 00 80 ff ff ff 4f 00 1d+11:45:14.481 READ DMA EXT
Error 4 occurred at disk power-on lifetime: 7768 hours (323 days + 16 hours)
25 00 80 ff ff ff 4f 00 1d+11:45:14.478 READ DMA EXT
Error 3 occurred at disk power-on lifetime: 7768 hours (323 days + 16 hours)
25 00 80 ff ff ff 4f 00 1d+11:45:14.421 READ DMA EXT
Error 2 occurred at disk power-on lifetime: 7768 hours (323 days + 16 hours)
Error 1 occurred at disk power-on lifetime: 7768 hours (323 days + 16 hours)
25 00 08 ff ff ff 4f 00 1d+11:45:14.420 READ DMA EXT
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas] /# smartctl -a /dev/ada3
Serial Number: 6YD0JY6M
LU WWN Device Id: 5 000c50 0373557bc
Local Time is: Mon Nov 10 12:53:54 2014 CST
been run.
command.
power-saving mode.
recommended polling time: ( 342) minutes.
1 Raw_Read_Error_Rate 0x000f 116 099 006 Pre-fail Always - 104170712
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 121
7 Seek_Error_Rate 0x000f 085 060 030 Pre-fail Always - 342325699
9 Power_On_Hours 0x0032 068 068 000 Old_age Always - 28479
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 121
188 Command_Timeout 0x0032 100 098 000 Old_age Always - 8590065697
189 High_Fly_Writes 0x003a 099 099 000 Old_age Always - 1
190 Airflow_Temperature_Cel 0x0022 065 052 045 Old_age Always - 35 (Min/Max 35/37)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 114
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 121
194 Temperature_Celsius 0x0022 035 048 000 Old_age Always - 35 (0 22 0 0 0)
195 Hardware_ECC_Recovered 0x001a 033 004 000 Old_age Always - 104170712
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 134922102665023
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 3117915189
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2865085598
No Errors Logged
# 1 Short offline Completed without error 00% 19409 -
# 2 Short offline Completed without error 00% 19407 -
# 3 Short offline Completed without error 00% 19405 -
# 4 Short offline Completed without error 00% 19404 -
# 5 Short offline Completed without error 00% 19403 -
# 6 Short offline Completed without error 00% 19402 -
# 7 Short offline Completed without error 00% 19401 -
# 8 Short offline Completed without error 00% 19400 -
# 9 Short offline Completed without error 00% 19399 -
#10 Short offline Completed without error 00% 19398 -
#11 Short offline Completed without error 00% 19397 -
#12 Short offline Completed without error 00% 19396 -
#13 Short offline Completed without error 00% 19395 -
#14 Short offline Completed without error 00% 14886 -
#15 Short offline Completed without error 00% 14646 -
#16 Short offline Completed without error 00% 14406 -
#17 Short offline Completed without error 00% 14142 -
#18 Short offline Completed without error 00% 13902 -
#19 Short offline Completed without error 00% 13663 -
#20 Short offline Completed without error 00% 13471 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas] /#
Well, the disk with serial number 6YD0PHJT logged some problem about 36 hours ago. So that drive in particular was the most recent to have problems.
I'd check to see if it has good power and data cables.
Your debug was a bit more interesting. The following problems were found:
ARP changes in dmesg which means conflicting IP addresses.
Samba errors related to null passwords being deprecated.
Conversation problems with smbd in the messages log.
LOTS of refused connections from 192.168.0.19 in the nginx-error.log
bad protocol version identifications from sshd in auth.log. I'm assuming this is because your ssh is open to the world???
There were some BIOS related messages on bootup that kind of hint that the hardware isn't the most ideal.
Other than that I'd say there is no smoking gun. But PSU and data cables are the first things I'd go checking.
