alberto2132
- Mar 30, 2023
When I try to connect to the network where it is, you thunder from a different network, it gives me an error.
These are the settings I've made:
Description = NAT Rule 1
Type = Command
Command = nft add table ip nat
When = Post Init
Description = NAT Rule 2
Type = Command
Command = nft 'add chain ip nat prerouting { type nat hook prerouting priority 0 ; }'
When = Post Init
Description = NAT Rule 3
Type = Command
Command = nft 'add chain ip nat postrouting { type nat hook postrouting priority 100 ; }'
When = Post Init
Description = NAT Rule 4
Type = Command
Command = nft 'add rule nat postrouting iifname $openvpn_interface_name oifname $network_interface_name saddr $vpn_subnet/24 masquerade'
When = Post Init
Type = Command
When = Post Init
Type = Command
When = Post Init
Type = Command
When = Post Init
Type = Command
When = Post Init
