- Oct 29, 2016
probably. i might have been a little melodramatic."you don't need to know the hardware" didn't go down well.That's a bit overstated.
I was trying to nice-ish; complete success not expected.
also, it just occurred to me, the PSU brand can matter as well.650W gold+ PSU
See, whenever someone starts to push me, I automatically go into defensive mode and absolutely won't play the game. That's what happened here.you said, but as you apparently refuse to post any hardware (if I missed it, please let me know), all we have is hearsay.
when I try to ask questions to clear up the mysteries, you try to Jedi your way out of giving any answers....
"the power supply....is fine"
"the hardware only draws 120w"
the 9305 is going to be ~5-20w on its own. each hard drive is ~10-20W idle, a bit more when spinning up. unless you have an ATOM cpu, most cpus are ~50Widle, motherboards are about 20W or so, any IPMI will be ~10W.
if you have 10 drives, that's already over what you claim your hardware uses, just in drives. most motherboards have 4-8 SATA ports, a primary reason to get a 9305 is because the motherboard doesn't have enough ports, which implies 6-10 drives minimum.
we don't know how many drives you have, we don't know the hardware. diagnosing issues blind is a frustrating waste of everyone's time.
I'm not even saying it's the power supply, I'm saying there isn't enough evidence to rule it out, yet, and that simply *following the rules of the forum* would aid that.
I am a very, very impatient and short-tempered person, and unless I am absolutely certain of what I do, I ask about it. Otherwise I present stuff as hard facts. Maybe I am an autist in this regard, but I kind of expect everyone else to be the same. Is that not true?Please don't do this. Try to assume that the community is well-meaning, and that we have indeed seen lots of stuff over the years.
Is there a way to add system specs into your profile or something at least, like you see on various IT forums? I wouldn't mind filling that in, but being asked for detailed system specs everytime you ask about something and knowing for a fact (that's disputable of course, but one should assume people know what they physically have next to them, especially when it's kinda special kind of equipment) that it's simply not related gets annoying pretty quickly![]()
I'm not sure how to clarify. I run TrueNAS virtualized. I don't think there's anything more to say?
Besides the current HBA being somewhat incompatible at random, shutting the VM down every two years or so, I was nothing but happy about this setup.
Ahh I read you.There's lots more to say. It can work out very well or it can totally suck. That's why there are several articles dedicated to the topic. How many cores are dedicated to the VM? How much memory? Is PCIe passthru set up properly? Are you using E1000{,E} or vmxnet3? Did you do anything bad to try to make use of disk resources, such as RDM?
Virtualized, yes, you can end up with a very happy setup if you do it right.
should be the virtual NIC type. i think esx had intel E1000 and one or 2 others? been awhile, and never used 6.7.E1000
I repeatedly read that the horrors of virtualizing TrueNAS were things of long time ago, and that seems to be my experience also.
Besides that one problem I had never anything weird happen that would indicate something caused directly by virtualization.
Well, those are more like configuration specifics than real problems caused by virtualization, aren't they?
