Nut and Collectd
aimdev
Hi
Can someone confirm that NUT and collectd are configured to work 'out of the box', or is theere more configuration to do.
My NUT client can see a non-freenas test system, on the freenas nothing.
User/password and remote set up as is the ups name.
Thanks
Aimee
D
dlavigne
Guest
Were you able to figure this out? If not, we'll need more details about your setup and what is not working.
DrKK
FreeNAS Generalissimo
Aimee: I can't speak for collectd. As for the nut server, on the FreeNAS side, in the services menu for UPS, you'll want to make sure "remote monitor" is set, or else nut won't listen for external clients. Alternatively, you can add:
LISTEN 0.0.0.0 {portnum}
into the "Auxiliary parameters (ups.conf)" box, and choose a portnum of your choice.
