I'm running TN Core 13.0.
I'm trying to get the AD users account to show up in the NSS information. My AD has the uidNumber/gidNumbers, and PrimaryGID(SP?) attributes properly filled. I join the TN server with the Active Directory integration without any errors. I make sure I'm using the idmap backend 'AD' type and the RFC2307 schema mode. When I go run the `getent passwd` on the shell as root, I only get the local user's listed. If it try `wbinfo -t`, `wbinfo -u` 'wbinfo -g`, then all return AD users properly.
Not sure why I'n not getting the user's in NSS.
root@FREENAS1:~ # midclt call activedirectory.config|jq
"id": 1,
"domainname": "EXAMPLE.INT",
"bindname": "user-admin",
"bindpw": "",
"verbose_logging": true,
"allow_trusted_doms": true,
"use_default_domain": false,
"allow_dns_updates": true,
"disable_freenas_cache": true,
"restrict_pam": false,
"site": "Default-First-Site-Name",
"timeout": 60,
"dns_timeout": 10,
"nss_info": "RFC2307",
"enable": true,
"kerberos_principal": "FREENAS1$@EXAMPLE.INT",
"createcomputer": "",
"kerberos_realm": 1,
"netbiosname": "FREENAS1",
"netbiosalias": []
root@FREENAS1:~ # testparm
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_DOMAIN_MEMBER
Press enter to see a dump of your service definitions
# Global parameters
[global]
aio max threads = 2
bind interfaces only = Yes
client ldap sasl wrapping = seal
disable spoolss = Yes
dns proxy = No
domain master = No
enable web service discovery = Yes
interfaces = 127.0.0.1 10.1.1.226
kerberos method = secrets and keytab
kernel change notify = No
load printers = No
local master = No
logging = file
max log size = 5120
preferred master = No
realm = EXAMPLE.INT
registry shares = Yes
restrict anonymous = 2
security = ADS
server multi channel support = No
server role = member server
template shell = /bin/sh
unix extensions = No
winbind cache time = 7200
winbind max domain connections = 10
winbind nss info = rfc2307
winbind use default domain = Yes
workgroup = EXAMPLE
idmap config stc: unix_primary_group = Yes
idmap config stc: schema_mode = rfc2307
idmap config stc: range = 10000-90000000
idmap config stc: backend = ad
fruit:nfs_aces = No
rpc_server:mdssvc = disabled
rpc_daemon:mdssd = disabled
idmap config * : backend = tdb
directory name cache size = 0
dos filemode = Yes
[SMB-Backups]
comment = Shared SMB Backups
ea support = No
kernel share modes = No
path = /mnt/VM_Vol1/SMB-Backups
posix locking = No
read only = No
smbd max xattr size = 2097152
vfs objects = fruit streams_xattr shadow_copy_zfs ixnas zfs_core aio_fbsd
fruit:resource = stream
fruit:metadata = stream
nfs4:chown = true
ixnas:dosattrib_xattr = false
