I'm running TN Core 13.0.
I'm trying to get the AD users account to show up in the NSS information. My AD has the uidNumber/gidNumbers, and PrimaryGID(SP?) attributes properly filled. I join the TN server with the Active Directory integration without any errors. I make sure I'm using the idmap backend 'AD' type and the RFC2307 schema mode. When I go run the `getent passwd` on the shell as root, I only get the local user's listed. If it try `wbinfo -t`, `wbinfo -u` 'wbinfo -g`, then all return AD users properly.
Not sure why I'n not getting the user's in NSS.
root@FREENAS1:~ # midclt call activedirectory.config|jq { "id": 1, "domainname": "EXAMPLE.INT", "bindname": "user-admin", "bindpw": "", "verbose_logging": true, "allow_trusted_doms": true, "use_default_domain": false, "allow_dns_updates": true, "disable_freenas_cache": true, "restrict_pam": false, "site": "Default-First-Site-Name", "timeout": 60, "dns_timeout": 10, "nss_info": "RFC2307", "enable": true, "kerberos_principal": "FREENAS1$@EXAMPLE.INT", "createcomputer": "", "kerberos_realm": 1, "netbiosname": "FREENAS1", "netbiosalias": [] }
root@FREENAS1:~ # testparm Load smb config files from /usr/local/etc/smb4.conf Loaded services file OK. Weak crypto is allowed Server role: ROLE_DOMAIN_MEMBER Press enter to see a dump of your service definitions # Global parameters [global] aio max threads = 2 bind interfaces only = Yes client ldap sasl wrapping = seal disable spoolss = Yes dns proxy = No domain master = No enable web service discovery = Yes interfaces = 127.0.0.1 10.1.1.226 kerberos method = secrets and keytab kernel change notify = No load printers = No local master = No logging = file max log size = 5120 nsupdate command = /usr/local/bin/samba-nsupdate -g preferred master = No realm = EXAMPLE.INT registry shares = Yes restrict anonymous = 2 security = ADS server multi channel support = No server role = member server server string = FreeNAS Server template shell = /bin/sh unix extensions = No winbind cache time = 7200 winbind max domain connections = 10 winbind nss info = rfc2307 winbind use default domain = Yes workgroup = EXAMPLE idmap config *: range = 90000001-100000000 idmap config stc: unix_primary_group = Yes idmap config stc: schema_mode = rfc2307 idmap config stc: range = 10000-90000000 idmap config stc: backend = ad fruit:nfs_aces = No rpc_server:mdssvc = disabled rpc_daemon:mdssd = disabled idmap config * : backend = tdb directory name cache size = 0 dos filemode = Yes [SMB-Backups] comment = Shared SMB Backups ea support = No kernel share modes = No path = /mnt/VM_Vol1/SMB-Backups posix locking = No read only = No smbd max xattr size = 2097152 vfs objects = fruit streams_xattr shadow_copy_zfs ixnas zfs_core aio_fbsd fruit:resource = stream fruit:metadata = stream nfs4:chown = true ixnas:dosattrib_xattr = false
