SOLVED Not all snapshots displayed when applying a filter
adrianwi
Not sure if this is a bug or an issue with my browser, but when I filter a list of snapshots they are not all being displayed when the setting for the number to display should show them all.
preview
You can see the the bottom of the 4th is cut-off and it should display another 2. If I click the right hand column twice I can see the other 2 but the screen still only shows 4 of 6.
D
dlavigne
Guest
Which browser and version? Also, does updating FreeNAS to the latest software update fix it?
adrianwi
Sorry, I should have tested this a little more first. It appears to be a Safari issue, as it works fine in IE and Chrome. I'll update the thread title.
