NOOB: How to create 10 disk ZFS pool consisting of 2 x 5 disk Z1 vdev?
esamett
I have been playing with the 8.0 GUI and have gotten "good" at creating and destroying ZFS volumes made out of a single vdev. It is not intuitively obvious to me how to create a volume consisting of two equal sized vdev of 5 disks each. The idea being to make upgrading easier in future.
Thanks.
it would be better to create a raidz2 out of all 10. it can always withstand loosing 2 disks whereas a stripped pair of 5 disk raidz's could sometimes but not all times withstand 2 lost disks. that being said, i too think the interface has been simplified to far, not allowing users to fully leverage the power of zfs.
emerge
Create a 5 disk raidZ volume
Create another 5 disk raidZ volume and use the same path as for the first volume you created
freenas will do # zpool add in the background, so you end up with a pool that consists of two raidZs like this:
freenas# zpool status
  pool: raid50
 state: ONLINE
 scrub: none requested
        NAME         STATE     READ WRITE CKSUM
        raid50       ONLINE       0     0     0
          raidz1     ONLINE       0     0     0
            gpt/da1  ONLINE       0     0     0
            gpt/da2  ONLINE       0     0     0
            gpt/da3  ONLINE       0     0     0
          raidz1     ONLINE       0     0     0
            gpt/da4  ONLINE       0     0     0
            gpt/da5  ONLINE       0     0     0
            gpt/da6  ONLINE       0     0     0
errors: No known data errors
