faisalm
- Feb 17, 2023
I'm doing some drive replacements on my zpool tank. The pool layout is 2 11-drive raidz3 vdevs. I also have 2 500GB SSDs which I've partitioned to use for mirrored log and special vdevs.
During the resilver process, the Web UI does not load up at all. All I see is the note "Waiting for Active TrueNAS controller to come up..." I can root around the CLI via SSH without issues. All other functions, including NAS services NFS and SMB, appear to be unaffected. I see the following nginx error in the systemd journal (with slightly redacted IP and domain info).
I'm upgrading drives 2 at a time using the following process, in case it's of any relevance:
Has anyone else seen this issue? What logs or other diagnostic information can I look for in the CLI? Thanks.
Mar 24 11:43:26 nas nginx[11574]: 2023/03/24 11:43:26 [error] 11574#11574: *15428 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 2001:db8:dead:beef::1, server: localhost, request: "GET /websocket HTTP/1.1", upstream: "http://127.0.0.1:6000/websocket", host: "nas.int.example.com"
- zpool offline 2 drives from vdev raidz3-0, then physically remove from server and set aside
- Install 2 new drives
- Initiate 2 drive replacements for vdev raidz3-1 in the Web UI, 1 after the other
- Run zpool resilver tank in the SSH to force the pool to resilver both drives at the same time rather than defer the second resilver
