No network in jails after upgrade to TrueNAS 13 (from Truenas 12) and restore config
netamego
After upgrade (from DVD) to new version of TrueNAS and restore config, my VMs networks works like expected but not my jail networks. The problem was in a the xml file of one of my VMs.
root@freenas[~]# grep bridge1 /etc/local/libvirt/bhyve/8_Docker.xml <source bridge='bridge1'/>
If I start TrueNas with this VM stopped, network jails works. If I start TrueNas with VM autostart enabled, additional bridge (to bridge0) named bridge1, is created and block bridge0 communications.
Once I have modified the /etc/local/libvirt/bhyve/8_Docker.xml file with the correct interface name (bridge0), the problems are gone. There is no option in web gui to change source bridge name.
Maybe this can help someone.
Best regards.
