I have previous used virtual box to install freenas as a test box so I don't mess up my current install. I'm not sure what happened but I can't access the internet from a jail but can from the host system. ping www.google.com and ping 192.168.5.1 (my gateway) only work in my host system but not in the jail.
I'm using VirtualBox 5.2.22 and have install FN 11.2U1 from scratch with networking set to bridge, 2 processors and 8gig of ram. I've tried to create a jail with the CLI and the GUI without any luck.
In the GUI I have the default IPV4 gateway and nameserver 1 set to 192.168.5.1
For example
give the error
ping: ssend socket: Operation not permitted
From the host
From the jail
My inpression is that with 11.2 you don't need the tuneables anymore. I hope someone has an idea what I'm doing wrong.
For example
iocage create -n test2 ip4_addr="em0|192.168.1.232/24" defaultrouter="192.168.5.1" -r 11.2-RELEASE iocage console test2 ping www.google.com
give the error
From the host
iocage list
| JID | NAME | STATE | RELEASE | IP4 |
| - | test | down | 11.2-RELEASE | 192.162.5.231 |
| 3 | test2 | up | 11.2-RELEASE | 192.168.1.232 |
root@freenas[~]# ifconfig
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM>
ether 08:00:27:41:88:35
hwaddr 08:00:27:41:88:35
inet 192.168.5.179 netmask 0xffffff00 broadcast 192.168.5.255
inet 192.168.1.232 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
ether 02:ef:0a:bd:ac:00
nd6 options=1<PERFORMNUD>
groups: bridge
member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 2000
member: vnet0:1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 4 priority 128 path cost 2000
member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
vnet0:1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: test
options=8<VLAN_MTU>
ether 02:ff:60:ae:1b:75
hwaddr 02:53:d0:00:04:0a
status: active
groups: epair
epair0b: flags=8842<BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:ff:60:ae:1b:76
hwaddr 02:53:d0:00:05:0b
status: active
vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
hwaddr 02:53:d0:00:06:0a
status: active
groups: epair
From the jail
root@test2:~ # ifconfig
status: active
groups: lo
groups: bridge
options=8<VLAN_MTU>
status: active
groups: epair
options=8<VLAN_MTU>
status: active
options=8<VLAN_MTU>
status: active
groups: epair
root@test2:~ # ping www.google.com
