Hello
I set the GUI to https and an other port. it work's fine. But now i wanted a own certificate.
I created a certificate with a Debian System. Afterwards i copied the public and private part to the GUI. Then I restart the NAS.
Now i can't get to the GUI. I tried the original IP and port, it didn't work. I also tried the IP and Port from the shell screen. it didn't work too.
I have physical access and can login to the shell. But my shell user can't get su.
Thanks for the Help
massage
nginx log
Thanks for the Help
massage
Aug 20 17:00:51 faraday root: /etc/rc: WARNING: failed precmd routine for vmware_guestd Aug 20 17:00:58 faraday ntpd[1587]: time reset +0.927418 s Aug 20 17:01:17 faraday proftpd[2158]: 127.0.0.1 - ProFTPD 1.3.3g (maint) (built Thu Jul 19 2012 19:57:37 UTC) standalone mod$ Aug 20 17:01:22 faraday root: /usr/local/etc/rc.d/nginx: WARNING: failed to start nginx
nginx log
2012/08/20 17:01:22 [emerg] 2346#0: SSL_CTX_use_PrivateKey_file("/etc/ssl/freenas/nginx/nginx.key") failed (SSL: error:0906D0$ 2012/08/20 17:01:22 [emerg] 2347#0: SSL_CTX_use_PrivateKey_file("/etc/ssl/freenas/nginx/nginx.key") failed (SSL: error:0906D0$
