NMI ...going to debug Console error message and lockup.
wbrco
Stymied.. I get this error after about 7 days of operation.
Did the ZFS Tuning tricks.
Nothing in syslog.
Any ideas?
FreeNAS-8.0.4-RELEASE-x86 (10351)
Dell SC440
4 Gig Ram
Dell SAS Controller.
Thanks!
wbrco
Hmm??
I guess I'll state the obvious..
Nothing in syslog that shows any errors
nothing in /var/opt/messages
I've ticked the "show syslog on gui" and have it in the bottom of the management.
I'm also collecting syslog in Zenoss Core. Nada, nothing that corresponds with the system lockup
(but tons of stuff @ startup :/ )
Machine was running Win 2003 32 bit fine until re-purposed for FreeNAS.
Is there a kernel debugger someplace? I'm not a FreeBSD guru, and even if I was I would be
a little leery of turning it on for performance issues.
ProtoSD
ZFS tuning tricks tend to do this when you least expect it. You might have a better chance of a helpful reply if you shared the tricks you tried, those would be the first thing I would suspect.
wbrco
kern.ipc.nmbclusters="25000"
vm.kmem_size="512M"
vm.kmem_size_max="512M"
vfs.zfs.arc_max="200M"
vfs.zfs.vdev.cache.size="20M"
These numbers are based on 4G of ram in the machine and the suggestions in http://wiki.freebsd.org/ZFSTuningGuide. These actually
helped, as it increased lockup from 3 days to about 7 days.
I did finally set /etc/rc.conf for dumpdev="/dev/md2" (my /var mount) and dumpdir="/var/crash"
I also set all the vmware tools in rc.conf to "NO" since I'm not running in VM.
wbrco
I wouldn't consider a Dell SC440 a small 32bit machine, considering that it has SAS RAID (Dell PERC 5i), 4G of ECC Ram, and in addition to the
Broadcom imbedded, an Intel Dual Pro 1000 nic.
The only reason I'm not running AM64 is that according to Dell it won't support 2G ram sticks to increase to 8G, and the FreeNAS documentation that I read says that anything less than 6G on AM64 is not recommended.
wbrco
FYI - Looks like my crash dump directory seems to be locked. I've changed the mount point for crash dumps to another partition.
Apr 18 13:07:21 freenas newsyslog[1448]: logfile first created
Apr 18 13:07:21 freenas kernel: Copyright (c) 1992-2011 The FreeBSD Project.
Apr 18 13:07:21 freenas kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Apr 18 13:07:21 freenas kernel: The Regents of the University of California. All rights reserved.
Apr 18 13:07:21 freenas kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Apr 18 13:07:21 freenas kernel: FreeBSD 8.2-RELEASE-p6 #0: Tue Feb 28 18:15:56 PST 2012
Apr 18 13:07:21 freenas kernel: root@build.ixsystems.com:/build/home/gcooper/e2e-bld.M6cSqeAx/obj.i386/i386/build/home/gcooper/e2e-bld.M6cSqeAx/FreeBSD/src/sys/FREENAS.i386 i386
Apr 18 13:07:21 freenas kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Apr 18 13:07:21 freenas kernel: CPU: Genuine Intel(R) CPU 2160 @ 1.80GHz (1795.55-MHz 686-class CPU)
Apr 18 13:07:21 freenas kernel: Origin = "GenuineIntel" Id = 0x6f2 Family = 6 Model = f Stepping = 2
Apr 18 13:07:21 freenas kernel: Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Apr 18 13:07:21 freenas kernel: Features2=0xe39d<SSE3,DTES64,MON,DS_CPL,EST,TM2,SSSE3,CX16,xTPR,PDCM>
Apr 18 13:07:21 freenas kernel: AMD Features=0x20000000<LM>
Apr 18 13:07:21 freenas kernel: AMD Features2=0x1<LAHF>
Apr 18 13:07:21 freenas kernel: TSC: P-state invariant
Apr 18 13:07:21 freenas kernel: real memory = 4294967296 (4096 MB)
Apr 18 13:07:21 freenas kernel: avail memory = 3669635072 (3499 MB)
Apr 18 13:07:21 freenas kernel: ACPI APIC Table: <DELL B8K >
Apr 18 13:07:21 freenas kernel: FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
Apr 18 13:07:21 freenas kernel: FreeBSD/SMP: 1 package(s) x 2 core(s)
Apr 18 13:07:21 freenas kernel: cpu0 (BSP): APIC ID: 0
Apr 18 13:07:21 freenas kernel: cpu1 (AP): APIC ID: 1
Apr 18 13:07:21 freenas kernel: ioapic0: Changing APIC ID to 8
Apr 18 13:07:21 freenas kernel: ioapic0 <Version 2.0> irqs 0-23 on motherboard
Apr 18 13:07:21 freenas kernel: lapic0: Forcing LINT1 to edge trigger
Apr 18 13:07:21 freenas kernel: kbd1 at kbdmux0
Apr 18 13:07:21 freenas kernel: cryptosoft0: <software crypto> on motherboard
Apr 18 13:07:21 freenas kernel: acpi0: <DELL B8K > on motherboard
Apr 18 13:07:21 freenas kernel: acpi0: [ITHREAD]
Apr 18 13:07:21 freenas kernel: acpi0: Power Button (fixed)
Apr 18 13:07:21 freenas kernel: acpi0: reservation of 0, a0000 (3) failed
Apr 18 13:07:21 freenas kernel: acpi0: reservation of 100000, f00000 (3) failed
Apr 18 13:07:21 freenas kernel: acpi0: reservation of 1000000, dee7cc00 (3) failed
Apr 18 13:07:21 freenas kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
Apr 18 13:07:21 freenas kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
Apr 18 13:07:21 freenas kernel: cpu0: <ACPI CPU> on acpi0
Apr 18 13:07:21 freenas kernel: cpu1: <ACPI CPU> on acpi0
Apr 18 13:07:21 freenas kernel: acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Apr 18 13:07:21 freenas kernel: Timecounter "HPET" frequency 14318180 Hz quality 900
Apr 18 13:07:21 freenas kernel: acpi_button0: <Power Button> on acpi0
Apr 18 13:07:21 freenas kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Apr 18 13:07:21 freenas kernel: pci0: <ACPI PCI bus> on pcib0
Apr 18 13:07:21 freenas kernel: pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
Apr 18 13:07:21 freenas kernel: pci1: <ACPI PCI bus> on pcib1
Apr 18 13:07:21 freenas kernel: em0: <Intel(R) PRO/1000 Network Connection 7.1.9> port 0xdcc0-0xdcdf mem 0xefd80000-0xefd9ffff,0xefda0000-0xefdbffff irq 16 at device 0.0 on pci1
Apr 18 13:07:21 freenas kernel: em0: Using an MSI interrupt
Apr 18 13:07:21 freenas kernel: em0: [FILTER]
Apr 18 13:07:21 freenas kernel: em0: Ethernet address: 00:15:17:d0:25:ce
Apr 18 13:07:21 freenas kernel: em1: <Intel(R) PRO/1000 Network Connection 7.1.9> port 0xdce0-0xdcff mem 0xefdc0000-0xefddffff,0xefde0000-0xefdfffff irq 17 at device 0.1 on pci1
Apr 18 13:07:21 freenas kernel: em1: Using an MSI interrupt
Apr 18 13:07:21 freenas kernel: em1: [FILTER]
Apr 18 13:07:21 freenas kernel: em1: Ethernet address: 00:15:17:d0:25:cf
Apr 18 13:07:21 freenas kernel: pcib2: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
Apr 18 13:07:21 freenas kernel: pci2: <ACPI PCI bus> on pcib2
Apr 18 13:07:21 freenas kernel: pcib3: <PCI-PCI bridge> at device 0.0 on pci2
Apr 18 13:07:21 freenas kernel: pci3: <PCI bus> on pcib3
Apr 18 13:07:21 freenas kernel: mpt0: <LSILogic SAS/SATA Adapter> port 0xcc00-0xccff mem 0xefbec000-0xefbeffff,0xefbf0000-0xefbfffff irq 16 at device 8.0 on pci3
Apr 18 13:07:21 freenas kernel: mpt0: [ITHREAD]
Apr 18 13:07:21 freenas kernel: mpt0: MPI Version=1.5.13.0
Apr 18 13:07:21 freenas kernel: mpt0: Capabilities: ( RAID-0 RAID-1E RAID-1 )
Apr 18 13:07:21 freenas kernel: mpt0: 1 Active Volume (2 Max)
Apr 18 13:07:21 freenas kernel: mpt0: 2 Hidden Drive Members (10 Max)
Apr 18 13:07:21 freenas kernel: pcib4: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
Apr 18 13:07:21 freenas kernel: pci4: <ACPI PCI bus> on pcib4
Apr 18 13:07:21 freenas kernel: pcib5: <ACPI PCI-PCI bridge> irq 17 at device 28.5 on pci0
Apr 18 13:07:21 freenas kernel: pci5: <ACPI PCI bus> on pcib5
Apr 18 13:07:21 freenas kernel: bge0: <Broadcom NetXtreme Gigabit Ethernet Controller, ASIC rev. 0x00b002> mem 0xefaf0000-0xefafffff irq 17 at device 0.0 on pci5
Apr 18 13:07:21 freenas kernel: bge0: CHIP ID 0x0000b002; ASIC REV 0x0b; CHIP REV 0xb0; PCI-E
Apr 18 13:07:21 freenas kernel: miibus0: <MII bus> on bge0
Apr 18 13:07:21 freenas kernel: brgphy0: <BCM5787 10/100/1000baseTX PHY> PHY 1 on miibus0
Apr 18 13:07:21 freenas kernel: brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
Apr 18 13:07:21 freenas kernel: bge0: Ethernet address: 00:1d:09:0d:a3:7d
Apr 18 13:07:21 freenas kernel: bge0: [FILTER]
Apr 18 13:07:21 freenas kernel: uhci0: <Intel 82801G (ICH7) USB controller USB-A> port 0xff80-0xff9f irq 21 at device 29.0 on pci0
Apr 18 13:07:21 freenas kernel: uhci0: [ITHREAD]
Apr 18 13:07:21 freenas kernel: usbus0: <Intel 82801G (ICH7) USB controller USB-A> on uhci0
Apr 18 13:07:21 freenas kernel: uhci1: <Intel 82801G (ICH7) USB controller USB-B> port 0xff60-0xff7f irq 22 at device 29.1 on pci0
Apr 18 13:07:21 freenas kernel: uhci1: [ITHREAD]
Apr 18 13:07:21 freenas kernel: usbus1: <Intel 82801G (ICH7) USB controller USB-B> on uhci1
Apr 18 13:07:21 freenas kernel: uhci2: <Intel 82801G (ICH7) USB controller USB-C> port 0xff40-0xff5f irq 18 at device 29.2 on pci0
Apr 18 13:07:21 freenas kernel: uhci2: [ITHREAD]
Apr 18 13:07:21 freenas kernel: usbus2: <Intel 82801G (ICH7) USB controller USB-C> on uhci2
Apr 18 13:07:21 freenas kernel: uhci3: <Intel 82801G (ICH7) USB controller USB-D> port 0xff20-0xff3f irq 23 at device 29.3 on pci0
Apr 18 13:07:21 freenas kernel: uhci3: [ITHREAD]
Apr 18 13:07:21 freenas kernel: usbus3: <Intel 82801G (ICH7) USB controller USB-D> on uhci3
Apr 18 13:07:21 freenas kernel: ehci0: <Intel 82801GB/R (ICH7) USB 2.0 controller> mem 0xff980800-0xff980bff irq 21 at device 29.7 on pci0
Apr 18 13:07:21 freenas kernel: ehci0: [ITHREAD]
Apr 18 13:07:21 freenas kernel: usbus4: EHCI version 1.0
Apr 18 13:07:21 freenas kernel: usbus4: <Intel 82801GB/R (ICH7) USB 2.0 controller> on ehci0
Apr 18 13:07:21 freenas kernel: pcib6: <ACPI PCI-PCI bridge> at device 30.0 on pci0
Apr 18 13:07:21 freenas kernel: pci6: <ACPI PCI bus> on pcib6
Apr 18 13:07:21 freenas kernel: vgapci0: <VGA-compatible display> port 0xbc00-0xbcff mem 0xe0000000-0xe7ffffff,0xef8f0000-0xef8fffff irq 19 at device 7.0 on pci6
Apr 18 13:07:21 freenas kernel: isab0: <PCI-ISA bridge> at device 31.0 on pci0
Apr 18 13:07:21 freenas kernel: isa0: <ISA bus> on isab0
Apr 18 13:07:21 freenas kernel: atapci0: <Intel ICH7 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xffa0-0xffaf irq 16 at device 31.1 on pci0
Apr 18 13:07:21 freenas kernel: ata0: <ATA channel 0> on atapci0
Apr 18 13:07:21 freenas kernel: ata0: [ITHREAD]
Apr 18 13:07:21 freenas kernel: atapci1: <Intel ICH7 SATA300 controller> port 0xfe00-0xfe07,0xfe10-0xfe13,0xfe20-0xfe27,0xfe30-0xfe33,0xfec0-0xfecf mem 0xeffffc00-0xefffffff irq 20 at device 31.2 on pci0
Apr 18 13:07:21 freenas kernel: atapci1: [ITHREAD]
Apr 18 13:07:21 freenas kernel: ata2: <ATA channel 0> on atapci1
Apr 18 13:07:21 freenas kernel: ata2: [ITHREAD]
Apr 18 13:07:21 freenas kernel: ata3: <ATA channel 1> on atapci1
Apr 18 13:07:21 freenas kernel: ata3: [ITHREAD]
Apr 18 13:07:21 freenas kernel: pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
Apr 18 13:07:21 freenas kernel: atrtc0: <AT realtime clock> port 0x70-0x7f irq 8 on acpi0
Apr 18 13:07:21 freenas kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Apr 18 13:07:21 freenas kernel: uart0: [FILTER]
Apr 18 13:07:21 freenas kernel: pmtimer0 on isa0
Apr 18 13:07:21 freenas kernel: orm0: <ISA Option ROMs> at iomem 0xc0000-0xc8fff,0xc9000-0xcefff,0xcf000-0xd0fff,0xd1000-0xd3fff pnpid ORM0000 on isa0
Apr 18 13:07:21 freenas kernel: sc0: <System console> at flags 0x100 on isa0
Apr 18 13:07:21 freenas kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Apr 18 13:07:21 freenas kernel: vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Apr 18 13:07:21 freenas kernel: atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
Apr 18 13:07:21 freenas kernel: atkbd0: <AT Keyboard> irq 1 on atkbdc0
Apr 18 13:07:21 freenas kernel: kbd0 at atkbd0
Apr 18 13:07:21 freenas kernel: atkbd0: [GIANT-LOCKED]
Apr 18 13:07:21 freenas kernel: atkbd0: [ITHREAD]
Apr 18 13:07:21 freenas kernel: ppc0: parallel port not found.
Apr 18 13:07:21 freenas kernel: coretemp0: <CPU On-Die Thermal Sensors> on cpu0
Apr 18 13:07:21 freenas kernel: est0: <Enhanced SpeedStep Frequency Control> on cpu0
Apr 18 13:07:21 freenas kernel: est: CPU supports Enhanced Speedstep, but is not recognized.
Apr 18 13:07:21 freenas kernel: est: cpu_vendor GenuineIntel, msr 928092806000928
Apr 18 13:07:21 freenas kernel: device_attach: est0 attach returned 6
Apr 18 13:07:21 freenas kernel: p4tcc0: <CPU Frequency Thermal Control> on cpu0
Apr 18 13:07:21 freenas kernel: coretemp1: <CPU On-Die Thermal Sensors> on cpu1
Apr 18 13:07:21 freenas kernel: est1: <Enhanced SpeedStep Frequency Control> on cpu1
Apr 18 13:07:21 freenas kernel: device_attach: est1 attach returned 6
Apr 18 13:07:21 freenas kernel: p4tcc1: <CPU Frequency Thermal Control> on cpu1
Apr 18 13:07:21 freenas kernel: fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Apr 18 13:07:21 freenas kernel: Timecounters tick every 1.000 msec
Apr 18 13:07:21 freenas kernel: usbus0: 12Mbps Full Speed USB v1.0
Apr 18 13:07:21 freenas kernel: usbus1: 12Mbps Full Speed USB v1.0
Apr 18 13:07:21 freenas kernel: usbus2: 12Mbps Full Speed USB v1.0
Apr 18 13:07:21 freenas kernel: usbus3: 12Mbps Full Speed USB v1.0
Apr 18 13:07:21 freenas kernel: usbus4: 480Mbps High Speed USB v2.0
Apr 18 13:07:21 freenas kernel: ugen0.1: <Intel> at usbus0
Apr 18 13:07:21 freenas kernel: uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
Apr 18 13:07:21 freenas kernel: ugen1.1: <Intel> at usbus1
Apr 18 13:07:21 freenas kernel: uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
Apr 18 13:07:21 freenas kernel: ugen2.1: <Intel> at usbus2
Apr 18 13:07:21 freenas kernel: uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
Apr 18 13:07:21 freenas kernel: ugen3.1: <Intel> at usbus3
Apr 18 13:07:21 freenas kernel: uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
Apr 18 13:07:21 freenas kernel: ugen4.1: <Intel> at usbus4
Apr 18 13:07:21 freenas kernel: uhub4: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4
Apr 18 13:07:21 freenas kernel: mpt0:vol0(mpt0:0:0): Settings ( Member-WCE )
Apr 18 13:07:21 freenas kernel: mpt0:vol0(mpt0:0:0): Using Spare Pool: 0
Apr 18 13:07:21 freenas kernel: mpt0:vol0(mpt0:0:0): 2 Members:
Apr 18 13:07:21 freenas kernel: (mpt0:1:32:0): Stripe Position 0 Online
Apr 18 13:07:21 freenas kernel: (mpt0:1:1:0): Stripe Position 1 Online
Apr 18 13:07:21 freenas kernel: mpt0:vol0(mpt0:0:0): RAID-0 - Optimal
Apr 18 13:07:21 freenas kernel: mpt0:vol0(mpt0:0:0): Status ( Enabled )
Apr 18 13:07:21 freenas kernel: (mpt0:vol0:1): Physical (mpt0:0:1:0), Pass-thru (mpt0:1:0:0)
Apr 18 13:07:21 freenas kernel: (mpt0:vol0:1): Online
Apr 18 13:07:21 freenas kernel: (mpt0:vol0:0): Physical (mpt0:0:32:0), Pass-thru (mpt0:1:1:0)
Apr 18 13:07:21 freenas kernel: (mpt0:vol0:0): Online
Apr 18 13:07:21 freenas kernel: uhub0: 2 ports with 2 removable, self powered
Apr 18 13:07:21 freenas kernel: uhub1: 2 ports with 2 removable, self powered
Apr 18 13:07:21 freenas kernel: uhub2: 2 ports with 2 removable, self powered
Apr 18 13:07:21 freenas kernel: uhub3: 2 ports with 2 removable, self powered
Apr 18 13:07:21 freenas kernel: uhub4: 8 ports with 8 removable, self powered
Apr 18 13:07:21 freenas kernel: ugen2.2: <ALCOR> at usbus2
Apr 18 13:07:21 freenas kernel: uhub5: <ALCOR Generic USB Hub, class 9/0, rev 1.10/3.12, addr 2> on usbus2
Apr 18 13:07:21 freenas kernel: uhub5: 4 ports with 4 removable, self powered
Apr 18 13:07:21 freenas kernel: ugen2.3: <Cirque> at usbus2
Apr 18 13:07:21 freenas kernel: ukbd0: <GlidePoint> on usbus2
Apr 18 13:07:21 freenas kernel: kbd2 at ukbd0
Apr 18 13:07:21 freenas kernel: ugen2.4: <No brand> at usbus2
Apr 18 13:07:21 freenas kernel: ukbd1: <Keyboard> on usbus2
Apr 18 13:07:21 freenas kernel: kbd3 at ukbd1
Apr 18 13:07:21 freenas kernel: uhid0: <Mouse> on usbus2
Apr 18 13:07:21 freenas kernel: device_attach: uhid0 attach returned 12
Apr 18 13:07:21 freenas kernel: da0 at mpt0 bus 0 scbus0 target 0 lun 0
Apr 18 13:07:21 freenas kernel: da0: <Dell VIRTUAL DISK 1028> Fixed Direct Access SCSI-5 device
Apr 18 13:07:21 freenas kernel: da0: 300.000MB/s transfers
Apr 18 13:07:21 freenas kernel: da0: Command Queueing enabled
Apr 18 13:07:21 freenas kernel: da0: 953674MB (1953124352 512 byte sectors: 255H 63S/T 121576C)
Apr 18 13:07:21 freenas kernel: cd0 at ata0 bus 0 scbus2 target 0 lun 0
Apr 18 13:07:21 freenas kernel: cd0: <PBDS CD-ROM DH-48N1P AD11> Removable CD-ROM SCSI-0 device
Apr 18 13:07:21 freenas kernel: cd0: 33.300MB/s transfers (UDMA2, ATAPI 12bytes, PIO 65534bytes)
Apr 18 13:07:21 freenas kernel: cd0: Attempt to query device size failed: NOT READY, Medium not present
Apr 18 13:07:21 freenas kernel: ada0 at ata2 bus 0 scbus3 target 0 lun 0
Apr 18 13:07:21 freenas kernel: ada0: <WDC WD2500AAKS-00VYA0 12.01B02> ATA-8 SATA 2.x device
Apr 18 13:07:21 freenas kernel: ada0: 150.000MB/s transfers (SATA, UDMA5, PIO 8192bytes)
Apr 18 13:07:21 freenas kernel: ada0: 238475MB (488397168 512 byte sectors: 16H 63S/T 16383C)
Apr 18 13:07:21 freenas kernel: ada1 at ata2 bus 0 scbus3 target 1 lun 0
Apr 18 13:07:21 freenas kernel: ada1: <WDC WD2500AAKS-00VYA0 12.01B02> ATA-8 SATA 2.x device
Apr 18 13:07:21 freenas kernel: ada1: 150.000MB/s transfers (SATA, UDMA5, PIO 8192bytes)
Apr 18 13:07:21 freenas kernel: ada1: 238475MB (488397168 512 byte sectors: 16H 63S/T 16383C)
Apr 18 13:07:21 freenas kernel: pass1 at mpt0 bus 1 scbus1 target 0 lun 0
Apr 18 13:07:21 freenas kernel: pass1: <SEAGATE ST3500414SS KS64> Fixed Uninstalled SCSI-5 device
Apr 18 13:07:21 freenas kernel: pass1: 300.000MB/s transfers
Apr 18 13:07:21 freenas kernel: pass1: Command Queueing enabled
Apr 18 13:07:21 freenas kernel: lapic1: Forcing LINT1 to edge trigger
Apr 18 13:07:21 freenas kernel: SMP: AP CPU #1 Launched!
Apr 18 13:07:21 freenas kernel: GEOM: da0: the secondary GPT header is not in the last LBA.
Apr 18 13:07:21 freenas kernel: Trying to mount root from ufs:/dev/ufs/FreeNASs1a
Apr 18 13:07:21 freenas kernel: WARNING: /data was not properly dismounted
Apr 18 13:07:21 freenas kernel: ZFS NOTICE: Prefetch is disabled by default on i386 -- to enable,
Apr 18 13:07:21 freenas kernel: add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
Apr 18 13:07:21 freenas kernel: ZFS filesystem version 4
Apr 18 13:07:21 freenas kernel: ZFS storage pool version 15
Apr 18 13:07:21 freenas kernel: GEOM: zvol/Long-Term-Store/LongTermStorage: partition 1 does not start on a track boundary.
Apr 18 13:07:21 freenas kernel: GEOM: zvol/Long-Term-Store/LongTermStorage: partition 1 does not end on a track boundary.
Apr 18 13:07:21 freenas savecore: /dev/md2: Operation not permitted
Apr 18 13:07:47 freenas istgt[2372]: istgt_iscsi.c: 859:istgt_iscsi_write_pdu_internal: ***ERROR*** iscsi_write() failed
Apr 18 13:07:47 freenas istgt[2372]: istgt_iscsi.c:3072:istgt_iscsi_transfer_in_internal: ***ERROR*** iscsi_write_pdu() failed
Apr 18 13:07:47 freenas istgt[2372]: istgt_iscsi.c:3437:istgt_iscsi_task_response: ***ERROR*** iscsi_transfer_in() failed
Apr 18 13:07:47 freenas istgt[2372]: istgt_iscsi.c:4957:sender: ***ERROR*** iscsi_task_response() failed on iqn.2011-03.example.org.istgt:longterm,t,0x0001(longterm,i,0x400001370001)
