Dorin
- Mar 31, 2014
Machine: Dual Core E5300, 8GB RAM, 2X2TB SATA hard disks, FreeNAS 9.2.1.8
I get tons of errors like this:
This IP is on my lab is the VMWare VCSA, and this error appears only to this machine. The mount is NFS and it's mounted on other machines, and I don't get any error regarding their IP's.
I checked rpcinfo -p localhost - everything looks perfectly ok (output here: http://pastebin.com/PvNarCCx )
Mounting the NFS volume on other machines (after this error) works, but the speed is really slow - 5MB on average, compared to 50+MB per second when this issue doesn't occur.
I had this error since 9.2.1.3 and then I updated to 9.2.1.8. The error didn't appear for few ours, but now it does...
No errors appear in /var/log/messages (other then this error):
Any suggestions?
Oct 31 00:37:16 freenas kernel: NLM: failed to contact remote rpcbind, stat = 7, addr = 192.168.0.50, port = 28416
Oct 31 00:37:17 freenas last message repeated 9 times
Oct 31 00:38:49 freenas last message repeated 10 times
Oct 30 12:04:57 freenas notifier: collectd not running?
Oct 30 12:04:57 freenas notifier: Starting collectd.
Oct 30 12:04:57 freenas notifier: kern.corefile: %N.core -> /mnt/main/.system/cores/%N.core
Any suggestions?
