Dear TrueNAS Community,
I'm writing to you today because I'm having trouble with my TrueNAS Scale. I had previously configured NFS and had it working, but I then turned NFS off and haven't used it in a while. Now that I want to enable NFS again with new shares, I'm getting an error that the service can't be started. If i change the port 2049 to 2048 the service is starting, but some devices uses only the original NFS ports and i can not use aditional ports. With netstat -tulnp i dont see the port 2049 is used.?
I would be grateful if someone could help me debug this issue. I can provide any additional information that is needed, but I need to know what logs or output would be useful for debugging.
Thank you for your time and assistance.
Overview
Platform:Generic
Version:
TrueNAS-SCALE-23.10.0.1
assignment
Hostname:truenas
Uptime:4 days, 19:24 as of 11:22
Error Message:
[EFAULT] Nov 15 18:49:09 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 15 18:49:10 systemd[1]: Finished nfs-server.service - NFS server and services. Nov 16 05:42:16 systemd[1]: Stopping nfs-server.service - NFS server and services... Nov 16 05:42:16 systemd[1]: nfs-server.service: Deactivated successfully. Nov 16 05:42:16 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 05:42:33 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 05:42:33 rpc.nfsd[190051]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 05:42:33 rpc.nfsd[190051]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 05:42:33 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 05:42:33 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 05:42:33 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 05:47:56 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 05:47:56 rpc.nfsd[2565]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 05:47:56 rpc.nfsd[2565]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 05:47:56 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 05:47:56 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 05:47:56 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 06:12:32 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 06:12:32 rpc.nfsd[20162]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 06:12:32 rpc.nfsd[20162]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 06:12:32 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 06:12:32 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 06:12:32 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 06:13:23 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 06:13:23 systemd[1]: Finished nfs-server.service - NFS server and services. Nov 16 06:14:54 systemd[1]: Stopping nfs-server.service - NFS server and services... Nov 16 06:14:55 systemd[1]: nfs-server.service: Deactivated successfully. Nov 16 06:14:55 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 06:14:55 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 06:14:55 systemd[1]: Finished nfs-server.service - NFS server and services. Nov 16 06:18:49 systemd[1]: Stopping nfs-server.service - NFS server and services... Nov 16 06:18:49 systemd[1]: nfs-server.service: Deactivated successfully. Nov 16 06:18:49 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:04:01 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:04:01 rpc.nfsd[242326]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 18:04:01 rpc.nfsd[242326]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 18:04:01 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 18:04:01 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 18:04:01 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:07:38 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:07:38 rpc.nfsd[243459]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 18:07:38 rpc.nfsd[243459]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 18:07:38 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 18:07:38 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 18:07:38 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:08:22 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:08:22 rpc.nfsd[243700]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 18:08:22 rpc.nfsd[243700]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 18:08:22 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 18:08:22 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 18:08:22 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:09:32 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:09:32 rpc.nfsd[244186]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 18:09:32 rpc.nfsd[244186]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 18:09:32 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 18:09:32 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 18:09:32 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:09:54 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:09:54 rpc.nfsd[244327]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 18:09:54 rpc.nfsd[244327]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 18:09:54 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 18:09:54 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 18:09:54 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:10:09 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:10:09 systemd[1]: Finished nfs-server.service - NFS server and services. Nov 16 18:10:15 systemd[1]: Stopping nfs-server.service - NFS server and services... Nov 16 18:10:15 systemd[1]: nfs-server.service: Deactivated successfully. Nov 16 18:10:15 systemd[1]: Stopped nfs-server.service - NFS server and services. Dec 07 11:23:13 systemd[1]: Starting nfs-server.service - NFS server and services... Dec 07 11:23:13 rpc.nfsd[2148401]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Dec 07 11:23:13 rpc.nfsd[2148401]: rpc.nfsd: unable to set any sockets for nfsd Dec 07 11:23:13 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Dec 07 11:23:13 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Dec 07 11:23:13 systemd[1]: Stopped nfs-server.service - NFS server and services.
remove_circle_outline
RAW Logs
Netstat
Lsof:
Overview
Platform:Generic
Version:
assignment
Hostname:truenas
Error Message:
RAW Logs
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 201, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1341, in _call return await methodobj(*prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf res = await f(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/service.py", line 191, in start raise CallError(await service_object.failure_logs() or 'Service not running after start') middlewared.service_exception.CallError: [EFAULT] Nov 15 18:49:09 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 15 18:49:10 systemd[1]: Finished nfs-server.service - NFS server and services. Nov 16 05:42:16 systemd[1]: Stopping nfs-server.service - NFS server and services... Nov 16 05:42:16 systemd[1]: nfs-server.service: Deactivated successfully. Nov 16 05:42:16 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 05:42:33 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 05:42:33 rpc.nfsd[190051]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 05:42:33 rpc.nfsd[190051]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 05:42:33 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 05:42:33 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 05:42:33 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 05:47:56 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 05:47:56 rpc.nfsd[2565]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 05:47:56 rpc.nfsd[2565]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 05:47:56 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 05:47:56 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 05:47:56 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 06:12:32 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 06:12:32 rpc.nfsd[20162]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 06:12:32 rpc.nfsd[20162]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 06:12:32 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 06:12:32 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 06:12:32 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 06:13:23 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 06:13:23 systemd[1]: Finished nfs-server.service - NFS server and services. Nov 16 06:14:54 systemd[1]: Stopping nfs-server.service - NFS server and services... Nov 16 06:14:55 systemd[1]: nfs-server.service: Deactivated successfully. Nov 16 06:14:55 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 06:14:55 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 06:14:55 systemd[1]: Finished nfs-server.service - NFS server and services. Nov 16 06:18:49 systemd[1]: Stopping nfs-server.service - NFS server and services... Nov 16 06:18:49 systemd[1]: nfs-server.service: Deactivated successfully. Nov 16 06:18:49 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:04:01 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:04:01 rpc.nfsd[242326]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 18:04:01 rpc.nfsd[242326]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 18:04:01 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 18:04:01 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 18:04:01 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:07:38 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:07:38 rpc.nfsd[243459]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 18:07:38 rpc.nfsd[243459]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 18:07:38 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 18:07:38 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 18:07:38 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:08:22 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:08:22 rpc.nfsd[243700]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 18:08:22 rpc.nfsd[243700]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 18:08:22 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 18:08:22 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 18:08:22 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:09:32 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:09:32 rpc.nfsd[244186]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 18:09:32 rpc.nfsd[244186]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 18:09:32 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 18:09:32 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 18:09:32 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:09:54 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:09:54 rpc.nfsd[244327]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Nov 16 18:09:54 rpc.nfsd[244327]: rpc.nfsd: unable to set any sockets for nfsd Nov 16 18:09:54 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Nov 16 18:09:54 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Nov 16 18:09:54 systemd[1]: Stopped nfs-server.service - NFS server and services. Nov 16 18:10:09 systemd[1]: Starting nfs-server.service - NFS server and services... Nov 16 18:10:09 systemd[1]: Finished nfs-server.service - NFS server and services. Nov 16 18:10:15 systemd[1]: Stopping nfs-server.service - NFS server and services... Nov 16 18:10:15 systemd[1]: nfs-server.service: Deactivated successfully. Nov 16 18:10:15 systemd[1]: Stopped nfs-server.service - NFS server and services. Dec 07 11:23:13 systemd[1]: Starting nfs-server.service - NFS server and services... Dec 07 11:23:13 rpc.nfsd[2148401]: rpc.nfsd: unable to bind AF_INET TCP socket: errno 98 (Address already in use) Dec 07 11:23:13 rpc.nfsd[2148401]: rpc.nfsd: unable to set any sockets for nfsd Dec 07 11:23:13 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Dec 07 11:23:13 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Dec 07 11:23:13 systemd[1]: Stopped nfs-server.service - NFS server and services.
Netstat
root@truenas[/home/admin]# netstat -tulnp Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name tcp 0 0 127.0.0.1:6444 0.0.0.0:* LISTEN 4362/k3s server tcp 0 0 127.0.0.1:6999 0.0.0.0:* LISTEN 2673/netdata tcp 0 0 172.16.0.217:5357 0.0.0.0:* LISTEN 3992/python3 tcp 0 0 0.0.0.0:6000 0.0.0.0:* LISTEN 774/middlewared tcp 0 0 127.0.0.1:10248 0.0.0.0:* LISTEN 4362/k3s server tcp 0 0 127.0.0.1:10259 0.0.0.0:* LISTEN 4362/k3s server tcp 0 0 127.0.0.1:10257 0.0.0.0:* LISTEN 4362/k3s server tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 2624/nginx: master tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 1/init tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 2497/sshd: /usr/sbi tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 2522/smbd tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 2522/smbd tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 2624/nginx: master tcp 0 0 127.0.0.1:10010 0.0.0.0:* LISTEN 5352/containerd tcp 0 0 172.16.0.217:179 0.0.0.0:* LISTEN 5515/kube-router tcp 0 0 172.16.0.218:5357 0.0.0.0:* LISTEN 3992/python3 tcp 0 0 172.16.0.217:50051 0.0.0.0:* LISTEN 5515/kube-router tcp 0 0 127.0.0.1:50051 0.0.0.0:* LISTEN 5515/kube-router tcp6 0 0 ::1:179 :::* LISTEN 5515/kube-router tcp6 0 0 :::6443 :::* LISTEN 4362/k3s server tcp6 0 0 :::29652 :::* LISTEN 8491/livenessprobe tcp6 0 0 :::29653 :::* LISTEN 5812/livenessprobe tcp6 0 0 :::29644 :::* LISTEN 8454/smbplugin tcp6 0 0 :::29642 :::* LISTEN 7446/livenessprobe tcp6 0 0 :::29643 :::* LISTEN 5839/livenessprobe tcp6 0 0 :::10250 :::* LISTEN 4362/k3s server tcp6 0 0 :::20244 :::* LISTEN 5515/kube-router tcp6 0 0 :::80 :::* LISTEN 2624/nginx: master tcp6 0 0 :::111 :::* LISTEN 1/init tcp6 0 0 :::22 :::* LISTEN 2497/sshd: /usr/sbi tcp6 0 0 :::139 :::* LISTEN 2522/smbd tcp6 0 0 :::445 :::* LISTEN 2522/smbd tcp6 0 0 :::443 :::* LISTEN 2624/nginx: master udp 0 0 127.0.0.1:941 0.0.0.0:* 2123733/rpc.statd udp 0 0 172.16.0.218:3702 0.0.0.0:* 3992/python3 udp 0 0 239.255.255.250:3702 0.0.0.0:* 3992/python3 udp 0 0 172.16.0.217:3702 0.0.0.0:* 3992/python3 udp 0 0 239.255.255.250:3702 0.0.0.0:* 3992/python3 udp 0 0 0.0.0.0:5353 0.0.0.0:* 3525/avahi-daemon: udp 0 0 0.0.0.0:47348 0.0.0.0:* 3992/python3 udp 0 0 0.0.0.0:39241 0.0.0.0:* 3525/avahi-daemon: udp 0 0 0.0.0.0:111 0.0.0.0:* 2123733/rpc.statd udp 0 0 0.0.0.0:111 0.0.0.0:* 1/init udp 0 0 0.0.0.0:123 0.0.0.0:* 2339/chronyd udp 0 0 172.18.203.171:137 0.0.0.0:* 4018/nmbd udp 0 0 172.18.203.171:137 0.0.0.0:* 4018/nmbd udp 0 0 172.18.95.108:137 0.0.0.0:* 4018/nmbd udp 0 0 172.18.95.108:137 0.0.0.0:* 4018/nmbd udp 0 0 172.18.0.10:137 0.0.0.0:* 4018/nmbd udp 0 0 172.18.0.10:137 0.0.0.0:* 4018/nmbd udp 0 0 172.18.0.1:137 0.0.0.0:* 4018/nmbd udp 0 0 172.18.0.1:137 0.0.0.0:* 4018/nmbd udp 0 0 172.17.255.255:137 0.0.0.0:* 4018/nmbd udp 0 0 172.17.0.1:137 0.0.0.0:* 4018/nmbd udp 0 0 172.16.0.255:137 0.0.0.0:* 4018/nmbd udp 0 0 172.16.0.217:137 0.0.0.0:* 4018/nmbd udp 0 0 172.16.0.255:137 0.0.0.0:* 4018/nmbd udp 0 0 172.16.0.218:137 0.0.0.0:* 4018/nmbd udp 0 0 0.0.0.0:137 0.0.0.0:* 4018/nmbd udp 0 0 172.18.203.171:138 0.0.0.0:* 4018/nmbd udp 0 0 172.18.203.171:138 0.0.0.0:* 4018/nmbd udp 0 0 172.18.95.108:138 0.0.0.0:* 4018/nmbd udp 0 0 172.18.95.108:138 0.0.0.0:* 4018/nmbd udp 0 0 172.18.0.10:138 0.0.0.0:* 4018/nmbd udp 0 0 172.18.0.10:138 0.0.0.0:* 4018/nmbd udp 0 0 172.18.0.1:138 0.0.0.0:* 4018/nmbd udp 0 0 172.18.0.1:138 0.0.0.0:* 4018/nmbd udp 0 0 172.17.255.255:138 0.0.0.0:* 4018/nmbd udp 0 0 172.17.0.1:138 0.0.0.0:* 4018/nmbd udp 0 0 172.16.0.255:138 0.0.0.0:* 4018/nmbd udp 0 0 172.16.0.217:138 0.0.0.0:* 4018/nmbd udp 0 0 172.16.0.255:138 0.0.0.0:* 4018/nmbd udp 0 0 172.16.0.218:138 0.0.0.0:* 4018/nmbd udp 0 0 0.0.0.0:138 0.0.0.0:* 4018/nmbd udp 0 0 127.0.0.1:323 0.0.0.0:* 2339/chronyd udp 0 0 0.0.0.0:57741 0.0.0.0:* 3992/python3 udp6 0 0 :::111 :::* 2123733/rpc.statd udp6 0 0 :::111 :::* 1/init udp6 0 0 :::123 :::* 2339/chronyd udp6 0 0 ::1:323 :::* 2339/chronyd
Lsof:
root@truenas[/home/admin]# lsof -i :2049 root@truenas[/home/admin]#
