hunt3ris
- Feb 11, 2022
I am trying to access my Nextcloud remotely and I get the untrusted domain prompt like when you first start the service. I changed that .PHP file to match my private IP and it worked without a hitch for the initial setup. I set up the port forwarding and the DDNS and it works if I put in the Truenas private IP, but not Nextcloud. The .PHP file was edited to match the DDNS address.
I followed this great guide:
www.truenas.com
I followed this post as a last-ditch effort to no avail:
www.truenas.com
Now I'm stumped on what to do now.
MOD - DO NOT USE THIS GUIDE - How to Set Up TrueNAS From Beginning to End - including secure remote access to files and Web GUI
This tutorial will go over all the basics in detail for a complete beginner that you will have to complete to set up a NAS on a dedicated machine you can access from both from a local and remote network securely, while also having the ability to SSH into the NAS securely remotely, allowing...
Nextcloud trust domain error in TrueNAS 12.0-RC1
Does anyone encounter the problem of trusted domain issue after a fresh install of Nextcloud plugin on TrueNAS 12.0-RC1? The Nextcloud config file only includes the IP address of the truenas server in the list of trusted domain, not the ip address of the nextcloud jail. In this case, the...
