SOLVED NextCloud red excalmation mark for external stroage
Artichoke
I have the nextcloud plugin installed but I want to be able to access other files on my server through the local storage plugin. I have a folder named 'npatrick' and another test dataset called 'dset1' and they are both in a pool called 'Main' . But when I try adding either of them with the Nextcloud external storage plugin, I just get a red exclamation mark. See below:
Artichoke
I solved the problem - I forgot about the fact that Nextcloud is running in a jail. All I needed to do was in the TrueNAS webUI, go to jails > Nextcloud > mount points > and then add a mount point leading to the dataset I wanted to add.
