I installed the nextcloud plugin on my freenas 11.2U5.
Once installed, a window with the data relating to the installation and the database should appear.
Database data does not appear.
How can I solve the problem? without the database data I cannot complete the nextcloud configuration.
Thank you.
Thank you.
Install Notes: nginx_enable: -> YES mysql_enable: -> YES php_fpm_enable: -> YES Performing sanity check on nginx configuration: Starting nginx. Performing sanity check on php-fpm configuration: Starting php_fpm. Starting mysql. Performing sanity check on php-fpm configuration: Stopping php_fpm. Waiting for PIDS: 24397. Performing sanity check on php-fpm configuration: Starting php_fpm. Performing sanity check on nginx configuration: Stopping nginx. Waiting for PIDS: 24382. Performing sanity check on nginx configuration: Starting nginx. Admin Portal: http://192.168.178.99
