new system Build v2 Help
ghost reaper
hey everyone
building new server in 4U rack 24bays Sata
do have 12bay already but running low on hdd space and failing backpanel and use to run freenas, but can only run windows becouse cant flash onboard sas, shity tyan server board, so going to start from scatch
system Usage: Plex 5 users max, might trans-code to android if file not supported, Owncloud backups, PVR
Parts on my list been looking see what over people saying
if got any recommendation let me know, or cheaper way but still want it last ages
know any good sites get parts cheaper, not cheap in australia motherboard is big cost
rack chassis: ednse ED424H65-T3 (all ready got one for $400 new)
spec sheet info https://userscloud.com/a73ilmtvgzm2
Mob: supermicro X10SL7-f $450
Cpu: Intel Pentium G3260 $90
RAM: Samsung 32G kit M393B5170EH1-CF8 PC3-8500R DDR3 ECC $60
PSU: Gigabyte 750W 80+ Gold Certified Modular Design ATX
GP-G750H $150
Usb: SANDISK EXTREME 32gb $28
Storage: lsi 9211-8i 6gbs sas 2 ports (8 sata) $120 future add on
MisterIce
Hey,
I'm fairly new myself so can't help you that much but if you want 5 Plex users + a few jails I can guarantee you that the Intel G3260 is not going to work.
The Plex website states that you need a passmark score of 2000 a single stream at a time. The CPU you've chosen scores 3466 on their list.
Here's the link to the Intel G3260: http://www.cpubenchmark.net/cpu_lookup.php?cpu=Intel+Pentium+G3260+@+3.30GHz&id=2523
If you want 5 users at a time you're better of getting a E3 Xeon.
Dice
I agree with @MisterIce.
Furthermore, there is no reason to get a X10 system these days. Skylake X11 is well supported.
Get one.
Look for a Xeon E3-1230.
ghost reaper
Thanks for feedback , is it really worth going to x11 just use new gen coy and ddr4 ram, I like x10 board for amount of data ports already on it,
Was going to get e3 cpu but notice someone else said don't need it they have same usage as me over then storage size, and trying not spend too much money or woman going give me headache haha ,
Stux
I think it's worth it to have a 64GB ram limit instead of 32GB.
The X11SSL-CF has 14 ports. You just need a breakout cable.
Start with 1 or 2 16GB sticks and you can still add a couple more later.
ghost reaper
Thanks for board number, i do like it but getting sold in Australia 600-650 know good external site ship to Australia, cheers
Stux
Newegg.
Search on the us site, add it to your cart. Then switch to the com.au site.
ghost reaper
No luck auto changes cart to out of stock without price
Stux
Guess they fixed that loophole :(
Stux
Might be worth trying wiredzone.com but their intl shipping is more than new eggs
ghost reaper
It was abit cheaper 550
I found this one in USA, .ca for 450 but diffrent number looks same
X11SSL-CF-O and another with b on end
Stux
https://forums.freenas.org/index.php?resources/so-you’ve-decided-to-buy-a-supermicro-x11-board.13/
-O vs -B model numbers
Many people get confused with these model numbers when they can only find an X10SL7-F-O, instead of an X10SL7-F, or an X10SLM+-F-B instead of an X10SLM+-F.
All model numbers are exactly as printed in their respective sections. For real products, they get either an -O or a -B appended to them, for retail or bulk packaging, respectively.
An example:
A Supermicro X10SL7-F-O is a retail-packaged X10SL7-F motherboard.
A Supermicro X10SL7-F-B is a bulk-packaged X10SL7-F motherboard.
What's the difference between them? With retail packaging, you get a box, with proper packaging materials. With bulk packaging, you get something along the lines of an antistatic bag, a bit of protective foam and some cardboard to wrap it all up.
ghost reaper
Stux
24 drives spinning up chews a lot of juice. I think the recommendation is normally 850.
Estimate is 30W per drive + the rest of your system.
I went with a 1000W but I have an E5 system.
ghost reaper
Oh ok I based it 25w per drive but some spec has change now, cheers
