UGH, the problems are now multiplying like rabbits.....On a different server than my previous post.
I just got this email error message;
So I logged into my server to see what's going on, and right away, the yellow button is flashing and I checked it. It tells me the following;
When I take a look at the pool, it seems that one of the drives is missing/not showing up. I found out that it's listed in the disks, but is definitely not listed in the volume. Also, when I view the volumes, it says that the pool is healthy. How can that be if the drive isn't even listed?
How do I determine if the drive needs to be replaced?
pool: TRINITY_RAID-01
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://www.sun.com/msg/ZFS-8000-9P
scan: scrub repaired 0 in 7h38m with 0 errors on Sun Feb 15 09:38:36 2015
NAME STATE READ WRITE CKSUM
TRINITY_RAID-01 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/934f3544-e66c-11e2-aea7-002590ab7843 ONLINE 0 0 0
gptid/93cb8c02-e66c-11e2-aea7-002590ab7843 ONLINE 0 0 0
gptid/944e85b1-e66c-11e2-aea7-002590ab7843 ONLINE 0 0 0
gptid/59c9cd9f-d827-11e3-b3b8-002590ab7843 ONLINE 0 0 0
gptid/95474b4f-e66c-11e2-aea7-002590ab7843 ONLINE 0 21.7K 0
gptid/6e0b6f9b-4a9a-11e4-88d2-002590ab7843 ONLINE 0 0 0
gptid/9644ecaf-e66c-11e2-aea7-002590ab7843 ONLINE 0 0 0
errors: No known data errorsSo I logged into my server to see what's going on, and right away, the yellow button is flashing and I checked it. It tells me the following;
WARNING: The volume TRINITY_RAID-01 (ZFS) status is UNKNOWN: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'.
