I'm new here, obviously, cause i'm in the newbie thread.
I've managed to set up my freenas and gain acces to the drive with several clients.
But now i'm trying to install the miniDLNA plugin.
However my plugins are not appearing (No entry has been found)
I've searched the forum but after two hours I can't see the forest behind the trees anymore.
I keep having the following errorcode:
I am not able to ping 8.8.8.8 in shell:
it says "ping: sendto: Invalid argument
Hostname: FREENAS
Domain: local
IPv4 Default Gateway: 192.168.0.1
Nameserver 1: 8.8.8.8
Nameserver 2: 8.8.4.4
With this information, can somebody help me back in the right direction.
All I need is that plugin.
May 23 00:12:44 FREENAS ntpd_initres[1950]: host name not found: 1.freebsd.pool.ntp.org May 23 00:12:44 FREENAS ntpd_initres[1950]: host name not found: 2.freebsd.pool.ntp.org May 23 00:14:46 FREENAS ntpd_initres[1950]: host name not found: 0.freebsd.pool.ntp.org May 23 00:14:46 FREENAS kernel: arpresolve: can't allocate llinfo for 192.168.0.1 May 23 00:14:46 FREENAS last message repeated 23 times
Hostname: FREENAS
Domain: local
