thedirtmerchant
 - Jun 26, 2012
So, I recently changed my 2 Wifi router network to a Google OnHub (TP-Link) and a Google Wifi puck using the "mesh".
For the many months prior to that, once I had gotten everything set up network wise, everything worked like a charm.
I followed Fester's and a few other people's setup info. Had Plex working w/o issues.
Router IP 192.168.0.1
DHCP Address Pool 192.168.0.100 thru 192.168.0.149
Once I changed to the OnHub, I went into settings and tried to mirror those same reservations.
However, I have had some issues with getting the Plex app to work and I noticed that in the
"Plugins>Available" I get a message "No entry has been found", which appears to be a network connectivity issue.
I tried changing the Nameservers (previously had 8.8.8.8 and 8.8.4.4) but now trying my router and google...
Researched a bit and what I'm seeing is it may be some kind of connectivity/network issue.
I tried pinging my router and Google (8.8.8.8) and get this:
IFCONFIG returns:
Thoughts anyone?
Name IPv4 Address IPv6 Address igb0 192.168.0.8/24 Nameserver 192.168.0.1 8.8.8.8 Default route 192.168.0.1
[root@Name ~]# ping 192.168.0.1 PING 192.168.0.1 (192.168.0.1): 56 data bytes 64 bytes from 192.168.0.1: icmp_seq=0 ttl=64 time=0.587 ms 64 bytes from 192.168.0.1: icmp_seq=1 ttl=64 time=0.352 ms 64 bytes from 192.168.0.1: icmp_seq=2 ttl=64 time=0.508 ms 64 bytes from 192.168.0.1: icmp_seq=3 ttl=64 time=0.582 ms 64 bytes from 192.168.0.1: icmp_seq=4 ttl=64 time=0.625 ms 64 bytes from 192.168.0.1: icmp_seq=5 ttl=64 time=0.559 ms 64 bytes from 192.168.0.1: icmp_seq=6 ttl=64 time=0.707 ms 64 bytes from 192.168.0.1: icmp_seq=7 ttl=64 time=0.441 ms 64 bytes from 192.168.0.1: icmp_seq=8 ttl=64 time=0.509 ms 64 bytes from 192.168.0.1: icmp_seq=9 ttl=64 time=0.657 ms 64 bytes from 192.168.0.1: icmp_seq=10 ttl=64 time=0.453 ms 64 bytes from 192.168.0.1: icmp_seq=11 ttl=64 time=0.569 ms 64 bytes from 192.168.0.1: icmp_seq=12 ttl=64 time=0.761 ms 64 bytes from 192.168.0.1: icmp_seq=13 ttl=64 time=0.532 ms 64 bytes from 192.168.0.1: icmp_seq=14 ttl=64 time=0.802 ms 64 bytes from 192.168.0.1: icmp_seq=15 ttl=64 time=0.557 ms 64 bytes from 192.168.0.1: icmp_seq=16 ttl=64 time=0.487 ms 64 bytes from 192.168.0.1: icmp_seq=17 ttl=64 time=0.481 ms 64 bytes from 192.168.0.1: icmp_seq=18 ttl=64 time=0.699 ms 64 bytes from 192.168.0.1: icmp_seq=19 ttl=64 time=0.688 ms 64 bytes from 192.168.0.1: icmp_seq=20 ttl=64 time=0.659 ms 64 bytes from 192.168.0.1: icmp_seq=21 ttl=64 time=0.602 ms 64 bytes from 192.168.0.1: icmp_seq=22 ttl=64 time=0.619 ms 64 bytes from 192.168.0.1: icmp_seq=23 ttl=64 time=0.541 ms 64 bytes from 192.168.0.1: icmp_seq=24 ttl=64 time=0.470 ms 64 bytes from 192.168.0.1: icmp_seq=25 ttl=64 time=0.603 ms 64 bytes from 192.168.0.1: icmp_seq=26 ttl=64 time=0.479 ms 64 bytes from 192.168.0.1: icmp_seq=27 ttl=64 time=0.519 ms 64 bytes from 192.168.0.1: icmp_seq=28 ttl=64 time=0.763 ms 64 bytes from 192.168.0.1: icmp_seq=29 ttl=64 time=0.586 ms 64 bytes from 192.168.0.1: icmp_seq=30 ttl=64 time=0.592 ms 64 bytes from 192.168.0.1: icmp_seq=31 ttl=64 time=0.571 ms 64 bytes from 192.168.0.1: icmp_seq=32 ttl=64 time=0.395 ms 64 bytes from 192.168.0.1: icmp_seq=33 ttl=64 time=0.590 ms 64 bytes from 192.168.0.1: icmp_seq=34 ttl=64 time=0.534 ms ^C[root@Name ~]# ^C
IFCONFIG returns:
[root@Name ~]# ifconfig igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6> ether 0c:c4:7a:e3:a3:b2 inet 192.168.0.8 netmask 0xffffff00 broadcast 192.168.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether 0c:c4:7a:e3:a3:b3 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:39:a1:8d:10:00 nd6 options=1<PERFORMNUD> id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 5 priority 128 path cost 2000 member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:05:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active
Thoughts anyone?
