Hi Patrick, thanks for you reply.
I didn't change any network settings in a long time. The server has been running well for over a year. After it first happened I decided to both upgrade TrueNAS and the Jails but that didn't help. I only have one physical interface connected which is also being used for IPMI.
I have a test Jail also which I did start after the last reboot. I just started it and there's no network connectivity in that Jail also. I can ping from inside the Jail to outside targets and I can't ping the IP address of the Jail from my PC. I can experiment with the settings of this Jail if you want.
# ifconfig
em0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=81249b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,LRO,WOL_MAGIC,VLAN_HWFILTER>
        ether 00:25:90:74:57:e1
        media: Ethernet autoselect
        status: no carrier
        nd6 options=1<PERFORMNUD>
em1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: em1
        options=812099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWFILTER>
        ether 00:25:90:74:57:e0
        inet 192.168.178.3 netmask 0xffffff00 broadcast 192.168.178.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
        groups: lo
pflog0: flags=0<> metric 0 mtu 33160
        groups: pflog
        ether 02:dc:dd:47:50:00
        maxage 20 holdcnt 6 proto stp-rstp maxaddr 2000 timeout 1200
        member: vnet0.9 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 14 priority 128 path cost 2000
        member: vnet0.8 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 13 priority 128 path cost 2000
        member: vnet0.7 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 12 priority 128 path cost 2000
        member: vnet0.6 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 11 priority 128 path cost 2000
        member: vnet0.5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 10 priority 128 path cost 2000
        member: vnet0.4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 9 priority 128 path cost 2000
        member: vnet0.3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 8 priority 128 path cost 2000
        member: vnet0.2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 7 priority 128 path cost 2000
        member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 6 priority 128 path cost 2000
        member: em1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 2 priority 128 path cost 20000
        groups: bridge
vnet0.1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: grafana as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:3e:10:b8
        hwaddr 02:83:d2:34:f6:0a
        groups: epair
        status: active
vnet0.2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: transmission as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:bb:2e:01
        hwaddr 02:b3:57:de:83:0a
        groups: epair
        status: active
vnet0.3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: jackett as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:96:a7:32
        hwaddr 02:62:fb:8d:2d:0a
        groups: epair
        status: active
vnet0.4: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: plex as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:7e:eb:bb
        hwaddr 02:d3:e8:31:99:0a
        groups: epair
        status: active
vnet0.5: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: sabnzbd as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:2e:9c:cb
        hwaddr 02:7c:c9:13:3b:0a
        groups: epair
        status: active
vnet0.6: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: tautulli as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:6f:2e:44
        hwaddr 02:a3:2f:1b:18:0a
        groups: epair
        status: active
vnet0.7: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: sonarr as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:60:65:8c
        hwaddr 02:dc:03:ea:1c:0a
        groups: epair
        status: active
vnet0.8: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: lidarr as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:bf:cd:2e
        hwaddr 02:51:ca:d3:23:0a
        groups: epair
        status: active
vnet0.9: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: radarr as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:e3:63:cb
        hwaddr 02:c0:84:41:19:0a
        groups: epair
        status: active
# dmesg
---<<BOOT>>---
Copyright (c) 1992-2020 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 12.2-RELEASE-p9 2ee62d665f0(HEAD) TRUENAS amd64
FreeBSD clang version 10.0.1 (git@github.com:llvm/llvm-project.git llvmorg-10.0.1-0-gef32c611aa2)
VT(efifb): resolution 800x600
CPU: Intel(R) Xeon(R) CPU E31260L @ 2.40GHz (2400.07-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x206a7  Family=0x6  Model=0x2a  Stepping=7
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x1dbae3ff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,XSAVE,OSXSAVE,AVX>
  AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
  AMD Features2=0x1<LAHF>
  Structured Extended Features3=0x9c000000<IBPB,STIBP,L1DFL,SSBD>
  XSAVE Features=0x1<XSAVEOPT>
  VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID
  TSC: P-state invariant, performance statistics
real memory  = 34359738368 (32768 MB)
avail memory = 33141325824 (31606 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <SUPERM SMCI--MB>
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 hardware threads
random: unblocking device.
ioapic0 <Version 2.0> irqs 0-23 on motherboard
Launching APs: 1 7 2 5 3 6 4
Timecounter "TSC-low" frequency 1200036432 Hz quality 1000
random: entropy device external interface
kbd1 at kbdmux0
mlx5en: Mellanox Ethernet driver 3.5.2 (September 2019)
nexus0
efirtc0: <EFI Realtime Clock> on motherboard
efirtc0: registered as a time-of-day clock, resolution 1.000000s
aesni0: No AES or SHA support.
padlock0: No ACE support.
cryptosoft0: <software crypto> on motherboard
acpi0: <SUPERM SMCI--MB> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
apei0: <ACPI Platform Error Interface> on acpi0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
mps0: <Avago Technologies (LSI) SAS2008> port 0xe000-0xe0ff mem 0xdfa40000-0xdfa4ffff,0xdfa00000-0xdfa3ffff irq 16 at device 0.0 on pci1
mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd
mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
em0: <Intel(R) PRO/1000 Network Connection> port 0xf020-0xf03f mem 0xdfc00000-0xdfc1ffff,0xdfc25000-0xdfc25fff irq 20 at device 25.0 on pci0
em0: Using 1024 TX descriptors and 1024 RX descriptors
em0: Using an MSI interrupt
em0: Ethernet address: 00:25:90:74:57:e1
ehci0: <Intel Cougar Point USB 2.0 controller> mem 0xdfc24000-0xdfc243ff irq 16 at device 26.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
usbus0: 480Mbps High Speed USB v2.0
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
pci3: <ACPI PCI bus> on pcib3
em1: <Intel(R) PRO/1000 Network Connection> port 0xd000-0xd01f mem 0xdfb00000-0xdfb1ffff,0xdfb20000-0xdfb23fff irq 16 at device 0.0 on pci3
em1: Using 1024 TX descriptors and 1024 RX descriptors
em1: Using 2 RX queues 2 TX queues
em1: Using MSI-X interrupts with 3 vectors
em1: Ethernet address: 00:25:90:74:57:e0
ehci1: <Intel Cougar Point USB 2.0 controller> mem 0xdfc23000-0xdfc233ff irq 23 at device 29.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci1
usbus1: 480Mbps High Speed USB v2.0
pcib4: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci4: <ACPI PCI bus> on pcib4
vgapci0: <VGA-compatible display> mem 0xde000000-0xdeffffff,0xdf800000-0xdf803fff,0xdf000000-0xdf7fffff irq 23 at device 3.0 on pci4
vgapci0: Boot video device
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel Cougar Point AHCI SATA controller> port 0xf070-0xf077,0xf060-0xf063,0xf050-0xf057,0xf040-0xf043,0xf000-0xf01f mem 0xdfc22000-0xdfc227ff irq 19 at device 31.2 on pci0
ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
ahciem0: <AHCI enclosure management bridge> on ahci0
acpi_button0: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: console (115200,n,8,1)
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart2: <16550 or compatible> port 0x3e8-0x3ef irq 10 on acpi0
ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
ichwd0: <Intel Cougar Point watchdog timer> on isa0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc87ff pnpid ORM0000 on isa0
superio0: <Nuvoton NCT6776> at port 0x2e-0x2f on isa0
wbwd0: <Nuvoton NCT6776 (0xc3/0x33) Watchdog Timer> at WDT ldn 0x08 on superio0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
Timecounters tick every 1.000 msec
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
ugen1.1: <Intel EHCI root HUB> at usbus1
ugen0.1: <Intel EHCI root HUB> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ipmi0: IPMI device rev. 1, firmware rev. 3.52, version 2.0, device support mask 0xbf
ipmi0: Number of channels 2
ipmi0: Attached watchdog
ipmi0: Establishing power cycle handler
Trying to mount root from zfs:freenas-boot/ROOT/12.0-U5 []...
Root mount waiting for: CAM usbus0 usbus1
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
ugen0.2: <vendor 0x8087 product 0x0024> at usbus0
uhub2 on uhub1
uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
ugen1.2: <vendor 0x8087 product 0x0024> at usbus1
uhub3 on uhub0
uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
uhub3: 6 ports with 6 removable, self powered
uhub2: 6 ports with 6 removable, self powered
ugen0.3: <Winbond Electronics Corp Hermon USB hidmouse Device> at usbus0
ums0 on uhub2
ums0: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10/0.01, addr 3> on usbus0
ums0: 3 buttons and [Z] coordinates ID=0
ugen1.3: <Corsair Commander PRO> at usbus1
ukbd0 on uhub2
ukbd0: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10/0.01, addr 3> on usbus0
kbd2 at ukbd0
uhid0 on uhub3
uhid0: <Corsair Commander PRO, class 0/0, rev 2.00/0.07, addr 3> on usbus1
ugen1.4: <vendor 0x05e3 USB2.0 Hub> at usbus1
uhub4 on uhub3
uhub4: <vendor 0x05e3 USB2.0 Hub, class 9/0, rev 2.00/32.98, addr 4> on usbus1
uhub4: MTT enabled
Root mount waiting for: CAM usbus1
uhub4: 4 ports with 4 removable, self powered
ses0 at ahciem0 bus 0 scbus7 target 0 lun 0
ses0: <AHCI SGPIO Enclosure 2.00 0001> SEMB S-E-S 2.00 device
ses0: SEMB SES Device
ada0 at ahcich0 bus 0 scbus1 target 0 lun 0
ada0: <SAMSUNG MZ7LM240HCGR-00005 GXT1003Q> ACS-2 ATA SATA 3.x device
ada0: Serial Number S2E5NXAGA01048
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 228936MB (468862128 512 byte sectors)
ada0: quirks=0x3<4K,NCQ_TRIM_BROKEN>
ses0: ada0 in 'Slot 00', SATA Slot: scbus1 target 0
ada1 at ahcich1 bus 0 scbus2 target 0 lun 0
ada1: <SAMSUNG MZ7LM240HCGR-00005 GXT1003Q> ACS-2 ATA SATA 3.x device
ada1: Serial Number S2E5NXAGA01052
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 228936MB (468862128 512 byte sectors)
ada1: quirks=0x3<4K,NCQ_TRIM_BROKEN>
ses0: ada1 in 'Slot 01', SATA Slot: scbus2 target 0
ada2 at ahcich5 bus 0 scbus6 target 0 lun 0
ada2: <SuperMicro SSD SOB20R> ACS-2 ATA SATA 3.x device
ada2: Serial Number SMC0515D94519B854045
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 512bytes)
ada2: Command Queueing enabled
ada2: 30208MB (61865984 512 byte sectors)
ses0: ada2 in 'Slot 05', SATA Slot: scbus6 target 0
da0 at mps0 bus 0 scbus0 target 4 lun 0
da0: <ATA WDC WD80EFAX-68K 0A81> Fixed Direct Access SPC-4 SCSI device
da0: Serial Number VDGWGP1D
da0: 7630885MB (15628053168 512 byte sectors)
da1 at mps0 bus 0 scbus0 target 5 lun 0
da1: <ATA WDC WD80EFAX-68K 0A81> Fixed Direct Access SPC-4 SCSI device
da1: Serial Number VDGV0SPD
da1: 7630885MB (15628053168 512 byte sectors)
da3 at mps0 bus 0 scbus0 target 7 lun 0
da3: <ATA WDC WD80EFAX-68K 0A81> Fixed Direct Access SPC-4 SCSI device
da3: Serial Number VAHTEG6L
da3: 600.000MB/s transfers
da3: Command Queueing enabled
da3: 7630885MB (15628053168 512 byte sectors)
da2 at mps0 bus 0 scbus0 target 6 lun 0
da2: <ATA WDC WD80EFAX-68K 0A81> Fixed Direct Access SPC-4 SCSI device
da2: Serial Number VAJ08P2L
da2: 600.000MB/s transfers
da2: 7630885MB (15628053168 512 byte sectors)
lo0: link state changed to UP
em1: link state changed to UP
GEOM_MIRROR: Device mirror/swap0 launched (2/2).
GEOM_ELI: Device mirror/swap0.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI:     Crypto: software
GEOM_MIRROR: Device mirror/swap1 launched (2/2).
GEOM_MIRROR: Device mirror/swap2 launched (2/2).
GEOM_ELI: Device mirror/swap1.eli created.
GEOM_ELI: Device mirror/swap2.eli created.
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> UCP/8/48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI>
em1: link state changed to DOWN
  Structured Extended Features3=0x9c000400<MD_CLEAR,IBPB,STIBP,L1DFL,SSBD>
Security policy loaded: MAC/ntpd (mac_ntpd)
bridge0: Ethernet address: 02:dc:dd:47:50:00
epair0a: Ethernet address: 02:83:d2:34:f6:0a
epair0b: Ethernet address: 02:83:d2:34:f6:0b
epair0a: link state changed to UP
epair0b: link state changed to UP
epair0a: changing name to 'vnet0.1'
bridge0: link state changed to UP
em1: promiscuous mode enabled
vnet0.1: promiscuous mode enabled
uhid0: at uhub3, port 3, addr 3 (disconnected)
uhid0: detached
epair1a: Ethernet address: 02:b3:57:de:83:0a
epair1b: Ethernet address: 02:b3:57:de:83:0b
epair1a: link state changed to UP
epair1b: link state changed to UP
epair1a: changing name to 'vnet0.2'
epair1b: changing name to 'epair0b'
vnet0.2: promiscuous mode enabled
tun0: link state changed to UP
tun0: changing name to 'wg0'
epair2a: Ethernet address: 02:62:fb:8d:2d:0a
epair2b: Ethernet address: 02:62:fb:8d:2d:0b
epair2a: link state changed to UP
epair2b: link state changed to UP
epair2a: changing name to 'vnet0.3'
epair2b: changing name to 'epair0b'
vnet0.3: promiscuous mode enabled
epair3a: Ethernet address: 02:d3:e8:31:99:0a
epair3b: Ethernet address: 02:d3:e8:31:99:0b
epair3a: link state changed to UP
epair3b: link state changed to UP
epair3a: changing name to 'vnet0.4'
epair3b: changing name to 'epair0b'
vnet0.4: promiscuous mode enabled
epair4a: Ethernet address: 02:7c:c9:13:3b:0a
epair4b: Ethernet address: 02:7c:c9:13:3b:0b
epair4a: link state changed to UP
epair4b: link state changed to UP
epair4a: changing name to 'vnet0.5'
epair4b: changing name to 'epair0b'
vnet0.5: promiscuous mode enabled
epair5a: Ethernet address: 02:a3:2f:1b:18:0a
epair5b: Ethernet address: 02:a3:2f:1b:18:0b
epair5a: link state changed to UP
epair5b: link state changed to UP
epair5a: changing name to 'vnet0.6'
epair5b: changing name to 'epair0b'
vnet0.6: promiscuous mode enabled
epair6a: Ethernet address: 02:dc:03:ea:1c:0a
epair6b: Ethernet address: 02:dc:03:ea:1c:0b
epair6a: link state changed to UP
epair6b: link state changed to UP
epair6a: changing name to 'vnet0.7'
epair6b: changing name to 'epair0b'
vnet0.7: promiscuous mode enabled
epair7a: Ethernet address: 02:51:ca:d3:23:0a
epair7b: Ethernet address: 02:51:ca:d3:23:0b
epair7a: link state changed to UP
epair7b: link state changed to UP
epair7a: changing name to 'vnet0.8'
epair7b: changing name to 'epair0b'
vnet0.8: promiscuous mode enabled
epair8a: Ethernet address: 02:c0:84:41:19:0a
epair8b: Ethernet address: 02:c0:84:41:19:0b
epair8a: link state changed to UP
epair8b: link state changed to UP
epair8a: changing name to 'vnet0.9'
epair8b: changing name to 'epair0b'
vnet0.9: promiscuous mode enabled
arp: 192.168.178.3 moved from 00:25:90:74:57:e0 to 02:ff:60:3e:10:b8 on epair0b
arp: 192.168.178.3 moved from 02:ff:60:3e:10:b8 to 00:25:90:74:57:e0 on epair0b
