net.inet.ip.scopedroute inside a jail?
DrKK
FreeNAS Generalissimo
....net.inet.ip.scopedroute is a Mac OSX sysctl and not a FreeBSD sysctl, and you are trying to install Mac OSX software on FreeBSD?
I mean, just a guess, sir. :)
pirateghost
Unintelligible Geek
Yeah. Just looking at the github it plainly says Mac and Linux. I don't see free BSD
DrKK
Yeah, this sysctl, I forget what it was for. Multiple gateway something-something, multiple ethernet something-something-something. Something-something firewall is broken something-something.
But it was definitely an Apple thing, as far as I can remember.
ovizii
not really, that github site says:
  • Your client machine (or router) is Linux, FreeBSD, or MacOS.
  • If you use MacOS or BSD on your client machine: Your kernel needs to be compiled with IPFIREWALL_FORWARD (MacOS has this by default) and you need to have ipfw available. (The server doesn't need to be MacOS or BSD.)
DrKK
Yeah it's not clear now what the hell he's talking about.
DrKK
Also, sshuttle (which I've never heard of) appears to be a VPN.
Installing a VPN in a FreeNAS jail (regardless of what these guys tell you here, and elsewhere) is highly non-trivial voodoo. Because of the way the jails work with the host network, it is very, very difficult/tricky and sometimes impossible to get it to work.
I don't suggest, really, that anyone try to get OpenVPN or any other VPN's working in jails. But that's me.
DrKK
And in any case, this doesn't change the fact that you can't change a sysctl that doesn't exist on the operating system. The evidence appears to be very strong that whatever software you're trying to install does not have FreeBSD in mind.
ovizii
Sorry for the confusion, I simply asked if this error rings
firewall manager: starting transproxy.
No such sysctl: 'net.inet.ip.scopedroute'
any bells with anyone:
BUT if you're wondering, of course I want to install sshuttle as a client, its not a server it simply connects to an sshd on the other end.
Regarding OPENVPN in a jail => https://forums.freenas.org/index.ph...-a-jail-so-it-only-connects-to-the-vpn.18669/
Does anyone know if:
the kernel used in a jail is compiled with IPFIREWALL_FORWARD?
