Need to set loader.conf.local variables in specific order
Osc4r
Hello!!, I'm using pfSense inside a bhyve virtual machine managed with iohyve. This VM has two dedicated NICs that are masked to the FreeNAS host using pptdevs. The host and VM interfaces are Realtek (I know they are not the best for FreeBSD) and I would like to use the Realtek's 1.95 driver for FreeBSD. Here comes the problem:
VMM module must be loaded before if_re module to mask the two interfaces for pfSense, however web gui doesn't allow to specify the order of variables in loader.conf.
If I manually set vmm_load before if_re_load in loader.conf.local, masking works correctly, but obviously, changes are lost on reboot.
Is there any way to solve this problem?
Samuel Tai
I have no idea if this will work, but FreeBSD, upon which FreeNAS is built, does have a rudimentary means of sequencing loader.conf entries. You could try setting the following loader tunables:
if_re_load="NO"
vmm_load="YES"
vmm_after="kldload if_re"
Osc4r
Ok, It did the trick!. Only one thing: command in "vmm_after" must be "load" instead of "kldload" to work.
if_re_load="NO"
vmm_load="YES"
vmm_after="load if_re"
Thank you very much Samuel!!
Samuel Tai
Sonovagun, it actually worked! :grin:
