Need some help with errors on upgrade to 11.2b3
bed
I've upgraded my hardware and moved from 9.10 to 11.2 beta 3. I imported one of my previous pools and added a new one (I always do full surface scans of new disks before putting them in my systems). Most things are working ok but I am still getting some errors and the system will become unresponsive. Im not sure but may be related to iscsi use. Last night it started when I fired up a few esxi VM's.
So far here are the errors I've observed:
(pages and pages of this one)
swap_pager: indefinite wait buffer: bufobj: 0, blkno:
error about binding web management IP (can't recall exact wording)
(see this on boot, ix10 is bound to management IP and SMB)
ix10 TS04 requires TXCSUM, disabling both
ix10 TS05 requires TXCSUM6, disabling both
All of these show up on the console. If I knew which logs would provide more information that would be helpful.
I've enabled system auto tune. Plex is installed. SMB is in use and so is ISCSI.
I found a reference to the swap_pager errors on the freenas bug tracker with a resolution of user configuration error located here https://redmine.ixsystems.com/issues/25136. I was not sure if this same thing is resulting in my problems or not. Every other search for this error was very dated freebsd blogs and mailing lists.
While I have been using freenas for a long time I am by no means an expert and could use any help at all.
D
dlavigne
Guest
It is probably worth reporting at bugs.freenas.org. If you do, post the issue number here.
