wolfman81
- Aug 19, 2018
can some one help me get plex installed on my nas i keep getting this error when trying to install
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/urllib/request.py", line 1318, in do_open
encode_chunked=req.has_header('Transfer-encoding'))
File "/usr/local/lib/python3.6/http/client.py", line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1026, in _send_output
self.send(msg)
File "/usr/local/lib/python3.6/http/client.py", line 964, in send
self.connect()
File "/usr/local/lib/python3.6/http/client.py", line 1392, in connect
super().connect()
File "/usr/local/lib/python3.6/http/client.py", line 936, in connect
(self.host,self.port), self.timeout, self.source_address)
File "/usr/local/lib/python3.6/socket.py", line 704, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/usr/local/lib/python3.6/socket.py", line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno 8] hostname nor servname provided, or not known
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 662, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 248, in fetch
iocage.fetch(**options)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/iocage.py", line 909, in fetch
props, accept_license=accept, official=official)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 690, in fetch_plugin_index
props, 0, accept_license)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 128, in fetch_plugin
self.__fetch_plugin_post_install__(conf, _conf, jaildir, jail_name)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 515, in __fetch_plugin_post_install__
self.__clone_repo(conf['artifact'], f'{jaildir}/plugin')
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 1233, in __clone_repo
remote_refs = client.fetch(repo_url, local)
File "/usr/local/lib/python3.6/site-packages/dulwich/client.py", line 363, in fetch
progress)
File "/usr/local/lib/python3.6/site-packages/dulwich/client.py", line 1398, in fetch_pack
b"git-upload-pack", url)
File "/usr/local/lib/python3.6/site-packages/dulwich/client.py", line 1282, in _discover_references
resp, read = self._http_request(url, headers, allow_compression=True)
File "/usr/local/lib/python3.6/site-packages/dulwich/client.py", line 1261, in _http_request
resp = self.opener.open(req)
File "/usr/local/lib/python3.6/urllib/request.py", line 526, in open
response = self._open(req, data)
File "/usr/local/lib/python3.6/urllib/request.py", line 544, in _open
'_open', req)
File "/usr/local/lib/python3.6/urllib/request.py", line 504, in _call_chain
result = func(*args)
File "/usr/local/lib/python3.6/urllib/request.py", line 1361, in https_open
context=self._context, check_hostname=self._check_hostname)
File "/usr/local/lib/python3.6/urllib/request.py", line 1320, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 8] hostname nor servname provided, or not known>
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run
await self.future
File "/usr/local/lib/python3.6/asyncio/coroutines.py", line 129, in throw
return self.gen.throw(type, value, traceback)
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 356, in __run_body
rv = await self.middleware._call_worker(self.serviceobj, self.method_name, *self.args, job={'id': self.id})
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 977, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 908, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 902, in run_in_executor
self.send(msg)
self.connect()
super().connect()
progress)
'_open', req)
raise URLError(err)
await self.future
job,
