Hi guys,
Thank you for a great forum. I am looking to build a NAS that can store data and stream two 1080p movies simultaneously via gigabit wired connection to my TVs.
Now I know many will say get mid to high-end cpus, but from reading, it seems that is a bit of an overkill, but hey, I'm not the expert, right? Also important is the amount of wattage as it's going to be on 24/7.
I don't:-
1. Mind buying 2nd hand parts if costs would be kept low.
2. Need anymore than 2 Bay Nas.
3. Need anymore than 2TB required.
4. Mind if using whatever case necessary.
You can use the http://uk.pcpartpicker.com to help me build the NAS. I to be honest don't know the cost, but so long as it can do what I need, then please don't go for expensive cpus and stuff...Cheap guys! ;)
So what can you recommend?
Thank you
I don't:-
Thank you
