need help, nas pool, can I reverse?
fakeNas
I have a pool with single HDD stripe, and I added a new HDD to this pool, and I did not start to use it yet, I mean I did not copy any data to this pool.
I changed my idea now, I want to use this new HDD as a new different pool itself standalone.
I deleted the virtual device of this new HDD, after restart the existing pool capacity not changed.
I cannot do anything with it. the shares from this existing pool still working.
what command shall I use? I just want to go back to the original state.
Show us the output of zpool status -v and glabel status
We can then see what's needed to proceed.
fakeNas
The "ada3p1" is the brand new HDD:
zfs command history:
2021-08-10.12:20:18 zpool import -d /dev -f -a
2021-08-10.12:51:44 zpool add -f workdatapool /dev/ada3p1
2021-08-10.16:47:09 zpool import -d /dev -f -a
2021-08-10.21:13:46 zpool import -d /dev -f -a
2021-08-10.21:52:33 zpool import -d /dev -f -a
2021-08-11.17:06:01 zpool import -d /dev -f -a
pool status:
pool: workdatapool
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
scan: none requested
NAME STATE READ WRITE CKSUM
workdatapool ONLINE 0 0 0
ada1 ONLINE 0 0 0
ada3p1 ONLINE 0 0 0
errors: No known data errors
So what you created there seems to be a striped pool (which risks pool loss if either of the 2 disks fails).
Did you do it via CLI yourself? Having the drives appear like that with the partitions as shown is a really odd result if you were using the GUI.
You may be able to remove the additional disk assuming your ZFS pool version is new enough (I see you haven't upgraded that pool and it's possibly too late to do it now).
zpool remove workdatapool /dev/ada3p1
You should really be a lot clearer in your mind/planning on how ZFS works and what you want to get from it.
Ideally use the GUI in all cases unless you really know what you're doing.
fakeNas
Thank you so much!
I have will try your code and get back to you later.
