Need Help Implementing iPerf Test Results
MarknSF
My question is how to convert iPerf setting into FreeBSD and win 7 settable parameters. I am a noob to FreeBSD and FreeNAS and so far the things I have tried haven't worked.
I have been doing performance tests on my recently constructed FreeNAS server running 9.2.0-RELEASE-x64 (ab098f4) on a Supermicro X10SLH-F motherboard with an E3-1230V3 processor, 24GB RAM, and M1015 controller with 24TB RAIDZ2 (5 3TB RED + 3 3TB Seagate NAS). The NAS will be used mostly for media storage and backup.
The client is Windows 7 SP1 platform with an I5-2500K, 16GB RAM, 256MB SSD and an Intel Gigiabit CT Desktop adapter connected to an 8-port 1Gb switch shared with the server.
FreeNAS autotune installed the following sysctls:
net.inet.tcp.sendbuf_max=2097152
net.inet.tcp.recvbuf_max=2097152
kern.ipc.maxsockbuf=2097152
Transfers of large files from the FreeNAS server to the client SSD exceed 95MB/s, great.
However, transfers from the SSD to the sever are closer to 45MB/s which is well below what the system should be capable of achieving.
Testing with iPerf (jPerf 2.0.2 on the client) over UDP showed transfer rates in both directions are very close the 1Gb/s theoretical limit, confirming there are no network hardware issues.
Testing with iPerf over TCP show a transfers from server to client at over well 900Mb/s,, again great. But the iPerf client to server test below shows there is a problem in upload direction (the .01 MByte window size ifs actually Windows 8kB default size):
bin/iperf.exe -c 192.168.44.44 -P 1 -i 2 -p 5001 -f m -t 20
Client connecting to 192.168.44.44, TCP port 5001
TCP window size: 0.01 MByte (default)
[156] local 192.168.44.32 port 51395 connected with 192.168.44.44 port 5001
[ ID] Interval      Transfer    Bandwidth
[156]  0.0- 2.0 sec  81.3 MBytes  341 Mbits/sec
[156]  2.0- 4.0 sec  65.8 MBytes  276 Mbits/sec
[156]  4.0- 6.0 sec  82.3 MBytes  345 Mbits/sec
[156]  6.0- 8.0 sec  82.2 MBytes  345 Mbits/sec
[156]  8.0-10.0 sec  81.4 MBytes  341 Mbits/sec
[156] 10.0-12.0 sec  81.9 MBytes  344 Mbits/sec
[156] 12.0-14.0 sec  82.3 MBytes  345 Mbits/sec
[156] 14.0-16.0 sec  80.0 MBytes  336 Mbits/sec
[156] 16.0-18.0 sec  80.9 MBytes  339 Mbits/sec
[156] 18.0-20.0 sec  81.0 MBytes  340 Mbits/sec
[156]  0.0-20.0 sec  799 MBytes  335 Mbits/sec
Done.
I have spent some time tuning parameters, primarily on the PC, most of which had little effect. The only parameter that had a significant impact was the TCP window size which when set on both the client and the server resolved the issue with 512k appearing to be the optimum value.
Here is a run with the just the client window set to 512k, a noticeable improvement:
bin/iperf.exe -c 192.168.44.44 -P 1 -i 2 -p 5001 -w 512.0K -f m -t 20
TCP window size: 0.50 MByte
[156] local 192.168.44.32 port 52065 connected with 192.168.44.44 port 5001
[156]  0.0- 2.0 sec  137 MBytes  575 Mbits/sec
[156]  2.0- 4.0 sec  143 MBytes  599 Mbits/sec
[156]  4.0- 6.0 sec  138 MBytes  578 Mbits/sec
[156]  6.0- 8.0 sec  138 MBytes  578 Mbits/sec
[156]  8.0-10.0 sec  142 MBytes  594 Mbits/sec
[156] 10.0-12.0 sec  146 MBytes  614 Mbits/sec
[156] 12.0-14.0 sec  124 MBytes  518 Mbits/sec
[156] 14.0-16.0 sec  122 MBytes  512 Mbits/sec
[156] 16.0-18.0 sec  145 MBytes  610 Mbits/sec
[156] 18.0-20.0 sec  142 MBytes  594 Mbits/sec
[156]  0.0-20.0 sec  1376 MBytes  577 Mbits/sec
Done.
Here is a test with just the server window set to 512k which is actually a little slower :
[156] local 192.168.44.32 port 52383 connected with 192.168.44.44 port 5001
[156]  0.0- 2.0 sec  62.1 MBytes  261 Mbits/sec
[156]  2.0- 4.0 sec  79.2 MBytes  332 Mbits/sec
[156]  4.0- 6.0 sec  75.5 MBytes  317 Mbits/sec
[156]  6.0- 8.0 sec  80.6 MBytes  338 Mbits/sec
[156]  8.0-10.0 sec  78.5 MBytes  329 Mbits/sec
[156] 10.0-12.0 sec  60.7 MBytes  255 Mbits/sec
[156] 12.0-14.0 sec  78.3 MBytes  329 Mbits/sec
[156] 14.0-16.0 sec  72.8 MBytes  305 Mbits/sec
[156] 16.0-18.0 sec  45.9 MBytes  193 Mbits/sec
[156] 18.0-20.0 sec  80.6 MBytes  338 Mbits/sec
[156]  0.0-20.0 sec  714 MBytes  299 Mbits/sec
Done.
But put them together and here is a test with both the client and server windows set to 512k:
[156] local 192.168.44.32 port 53119 connected with 192.168.44.44 port 5001
[156]  0.0- 2.0 sec  207 MBytes  868 Mbits/sec
[156]  2.0- 4.0 sec  224 MBytes  937 Mbits/sec
[156]  4.0- 6.0 sec  216 MBytes  907 Mbits/sec
[156]  6.0- 8.0 sec  226 MBytes  947 Mbits/sec
[156]  8.0-10.0 sec  222 MBytes  932 Mbits/sec
[156] 10.0-12.0 sec  226 MBytes  948 Mbits/sec
[156] 12.0-14.0 sec  207 MBytes  869 Mbits/sec
[156] 14.0-16.0 sec  224 MBytes  941 Mbits/sec
[156] 16.0-18.0 sec  226 MBytes  948 Mbits/sec
[156] 18.0-20.0 sec  220 MBytes  924 Mbits/sec
[156]  0.0-20.0 sec  2198 MBytes  922 Mbits/sec
Done.
It is unclear to me why it is necessary to set both windows on a one way transfer to achieve the desired performance but this is what the tests seem to indicate. Some how these 512k iPerf settings seem to resolve the problem but I am suspicious that both windows needed to be 512k for one direction while no new setting were needed for the other direction.
On the Windows 7 side MS implemented a "next generation TCP/IP stack" for Windows 7 SP1 which it suppose to magically adjust windows sizes as needed, there is not even a register entry for TCP windows size. I tried setting various options using TCPOptmizer.exe but none of them yielded results close the iPerf's. I assume iPerf is programmatically setting window size on the PC but this would probably have to be done on a per connection basis. I don't see how to implement it on the PC.
I would appreciate some pointers on translating the iPerf results into usable action. If there is something else going on that I'm missing please let me know.
Thanks
