Looking for a solid but affordable atx board that will support 20 drives + as well as decent PCIe sata/sas cards. I have a LSI 9260-8i RAID card but I was planning on using software raid although I honestly don't know if I should use hardware vs. software. I'd like to spend under $50 a card if that is possible. I will only need 3.
I have an antec 1200 I am going to mod with 4 http://www.moddiy.com/products/5%2din%2d3-Device-Module-Hard-Disk-Cage-SAS{47}SATA-Expander-Enclosure.html I don't want to crowd the case to much but the built in fan for each cage should keep things cool enough.
Also looking for ATX motherboard suggestions!
Thanks for the help,
Kevin
Kevin
