monden2
- Dec 18, 2017
Hi all!
I was wondering if you can help me with an idea that I have, and whether or not it will FreeNAS?
I have a gaming rig with 5820k CPU, 16gb RAM and dedicated GPU. Further, I have an 240GB SSD with Windows on it, as well as 1x 2TB HDD and 1x 4TB HDD.
On the side, I also have a WD MyCloud mirror with 2x 4TB HDD in RAID1.
Now I want to consolidate all this equipment into my gaming rig to maximise the speed I can get from this setup. I also want to set it up with FreeNAS, because in the future I want to be able to take it out of gaming rig and put it in a dedicated server NAS, where I can then also expand the ZFS volume with a secondary, identical 'vdev'.
So the idea I have is followed:
1. I want to have my standard Windows installation on my SSD, which uses most of my CPU cores and the dedicated GPU. I then want to use the 2TB drive for a secondary windows drive for active project work.
2. I want to run FreeNAS from a USB stick, to make a RAID5 style array (don't know what it is called in ZFS speak) from the 3x 4TB drives directly connected to the motherboard's SATA connections, which will be used for archive "server" with 1 drive redundancy. The array folders (datasets) will then be mapped in Windows to have direct access.
3. I want the server to also serve as a Plex Server for my house, as well as a network backup for the gaming rig's SSD and other wireless devices (the rig will be hard wired to the wireless router from my ISP).
So is this at all possible? And if so, how would I go about in setting it up? Do I simply leave the SSD and 2TB HDD as they are, format the 3x 4TB and boot FreeNAS from the USB (setting up the array with the 3 HDD'S)?
