MyNAS.local daily run output
Easygoer
I'm getting the following message as part of the daily run output. I haven't seen this msg. in the past come up at all. So this is new to me. My LSI HBA has been flashed to IT mode Version 20.04, so it is kind of unto date.
Her's what it says:
Checking status of 3ware RAID controllers:
Alarms (most recent first):
+++ /var/log/3ware_raid_alarms.today 2016-08-29 03:01:00.224715704 -0400
@@ -0,0 +1 @@
-- End of daily output --
Anything that I should be concerned about?.
Appreciate any input. Thanks.
Easygoer
Disabling the message (i.e., clicking the checkbox) doesn't remove the message, it just means that message won't turn the status light yellow or red.
D
dlavigne
Guest
I don't think it's related. That false alert fix will be going into the U1 update, due out in a few weeks.
