Mylar does not have permissions to create directories
pmgmr2
Hello! I'm on freenas 9.10 and I created a new jail with the Mylar plugin, and I mounted a storage point to /mnt/downloads/ directory, which contains my comics directory (/mnt/downloads/comics/)
Mylar seemed to work fine when I was adding the comics that have existing directories within it, but when I try to add a new comic (which means it would have to create a new directory) Mylar fails and the log says:
2016-06-01 13:53:30 WARNING [DIRECTORY-CHECK] Could not create directory: /media/comics/Superman (2016)[[Errno 13] Permission denied: '/media/comics/DC Universe Rebirth (2016)']. Aborting.
Any ideas? Thanks for your help.
pmgmr2
Oh wow, I was futzing around with it during initial setup and completely forgot to change the directories back so they matched....such a simple solution, that fixed it!! Thank you for the help
