Hi all
I have various extra hardware to possibly use to improve performance.
I ordered a quad port nic from ebay & have one already. They are fairly cheap.
I have one machine that needs fast network access to will use teaming to speed things up.
1 gigabit is too slow and 10 gigabit is expensive overkill.
So I have other hardware to be used if it will improve performance.
2 x old 60GB SSDs
2 more recent 240 GB SSDs.
They can be swapped to/from machines.
I store large media files and many smaller files.
When I sync across the network to my NAS it can be slow, especially when small files are involved. I typically use ubuntu OS with freefilesync for that.
Some datasets have sync on and some off.
Ideally they should all be on and would like that to be the case.
Will the 60 GB drives in mirrored configuration as a ZIL be a benefit. They are both Kingston V300 60 GB drives.
There are inexpensive 16GB intel optane drives available.
That is another option to use as a ZIL.
If I do that the 60GB drives could maybe be used as an L2ARC in striped configuration.
In my gaming machine I have a 256GB NVMe which a may use as an L2arc when replaced.
There are many different opinions as if that would be a benefit.
I have some virtual machines running also. - Windows 10, ubuntu server with network related activity always on & another ubuntu server specifically as a game cache.
I am looking to maybe have pfsense also as a virtual router.
That would mean around 8GB of RAM will allocated.
It is a home server with nothing critically important on there.
Everything is backed up on external hard drives.
Is a 16GB optane drive as ZIL benefitial?
Are 2 60GB SSDs mirrored useful as a ZIL?
Will they improve performance for my hard drive based Pool?
Thank you
2 x old 60GB SSDs
Thank you
