My processor does something odd every 30 min and I have no idea what or why...
Ceetan
My Little server was running smooth up untill about 2 weeks ago. At that point , it the processors started heating up every 30 min, causing the fans to speed up until it cooled again (working as intended) . It's been doing this ever since and I have no idea why.
It does not seem correlated with smarts or scrubs, I fear i may have malware. Any one have any idea on what to do about it or what could be causing it?
Fan Log with temps and such
Ceetan
Hardware for those that cannot see my sig
FreeNAS-9.10.2-U1 Stable
MOBO: Supermicro X11SSL-CF with
CPU: Intel Core i3-6100
RAM 2*16GB Crucial DDR4 ECC 2133MHz (CT2K16G4WFD8213)
8* WD Red WD40EFRX 64MB 4TB in RAIDZ2
BOOT: 90GB Corsair SSD
CASE: Fractal design node 804
PSU:EVGA SuperNOVA 650 G2
UPS: APC BE700G-GR
Fan Control: Hybrid CPU & HD Fan Zone Controller Script
BigDave
FreeNAS Enthusiast
It's interesting that your first thought is an infection/virus?
Is your FreeNAS accessable outside your LAN? If this is true,
you will need to give a full accounting of how you have this
set up before anyone could help you with this.
Stux
Fan log shows CPU fan not going past medium. HDs get up to 37C and 80%. Which is expected.
What you do see is the CPU seems to be doing some work every 30 mins.
Run a top process with processes sorted by instan usage and view it when the fans kick up. Should tell you what is causing it.
