My first FreeNAS Server
Mike Hope
Hi everybody!
Just completed my first FreeNAS Server consisting of an Intel Xeon E3-1231v3 on an Intel S1200V3RPL with 32GB ECC RAM. This has 2 GbE Intel i210 NICs.
Also added 6 x 6TB WD Reds to the internal SATA 6G ports.
Fresh install of 9.3stable to an USB Stick attached to the internal USB port. Then used the wizard to create a RaidZ2 VDEV/Zpool out of all 6 HDDs and some datasets.
Initial performance test saturated the GbE (110MB/s) while throwing 1TB of video TS files from my desktop computer (Intel NIC, LSI SAS Raid5 of 4 x 3TB WD Reds that yield 400MB/s when copying to internal SSD).
So far I was very happy with the result. More of that in a separate thread ...
Greetz,
Mike
gpsguy
Active Member
Mike, welcome to the forums!
Congratulations for reading the stickies and buying sever grade materials.
Welcome to the forum. Thanks for buying real hardware. You'll be much happier for it. :)
Mike Hope
Thanks for the welcomings.
I even thought about getting the Red Pros because of the better URE rating.
But I wanted as much capacity out of 6 drives as possible.
Also I would have used RaidZ3 with 7 drives if the MB had 7 SATA ports (don't want to use an additional SAS controller although there is an IBM M1015 lying around here).
