raymond_ma
- Nov 6, 2018
I am trying to use FreeNAS as a file sharing system among different users, but it seems strange to me that when some user uploads a file, other users cannot see it. I tried this on both 11.2 beta3 and RC1, and the same result. Here is what I do.
1. Create a storage and a dataset in Windows ACL type, share it with SMB named dataset01
2. Set the owner of dataset01 to user01
3. Connect to my server from a Windows client as user01, create folder01, folder02, etc
4. For the shared root folder, give user02 Read & Execute permission, using windows explorer
5. For folder02, give user02 Full Control permission
6. Log off and then reconnect to FreeNAS server as user02, now I can see folder01 and folder02 with no problem
7. Since user02 has full control access to folder02, I can now create new sub_folder and user02.txt under folder02
Here is my problem that when I check attributes of either sub_folder or user02.txt, it only has permissions for user02, but NOT for user01. It is also proved when I connect with user01 and see nothing under folder02. I guess the permissions for user01 should inherit from its parent folder, or not? I tried the same procedure on a pure windows server with SMB, and it works like a charm.
Any suggestions or any other solutions to my multi-user file sharing scenario are welcome. Thanks.
