After experiencing an high failure rate of USB sticks, I decided to move my boot pool to SSDs, but I have a couple of questions:
1) I'm using 64GB USB drives, should I use SSDs of the same or bigger capacity, right? I cannot use, for instance, a 32 GB SSD.
2) Which SSDs are recommended? Can I use SSDs with sata-usb3 adapter and connect the SSDs to the USB3 external ports? Or is better to avoid such devices? And what about PCI to m2 adapters?
Thanks in advance!
Thanks in advance!
