Moved data now errors?
RichTJ99
So I moved data from one pool to a newly created pool and now I am getting the following errors when logging into Freenas:
Of the system seems to have problems now. I used the command:
mv /mnt/Pool/Storage/data /* /mnt/Temp2tb/data (actual directories might be slightly different).
Now using commands like "ls" dont work at all anymore.
Request Method: GET
Request URL: http://192.168.1.45/system/info/?dojo.preventCache=1454164658342
Software Version: FreeNAS-9.3-STABLE-201512121950
Exception Type: OSError
Exception Value:
[Errno 2] No such file or directory
Exception Location: /usr/local/lib/python2.7/subprocess.py in _execute_child, line 1327
Server time: Sat, 30 Jan 2016 09:37:40 -0500
Traceback
Request information
GET
Variable Value
dojo.preventCache u'1454164658342'
POST
No POST data
FILES
No FILES data
COOKIES
Variable Value
csrftoken '4p0bY7s1O93rHu0iazklrjY2uL6ieEaE'
fntreeSaveStateCookie 'root%2Croot%2F188%2Croot%2F191%2F197%2F199%2Croot%2F191%2F207%2Croot%2F132%2Croot%2F38%2Croot%2F189%2Croot%2F191%2Croot%2F195%2Croot%2F193%2Croot%2F55%2Croot%2F55%2F56%2Croot%2F55%2F56%2F57%2Croot%2F55%2F56%2F57%2F58%2Croot%2F55%2F56%2F57%2F58%2F83%2Croot%2F55%2F56%2F57%2F58%2F87%2Croot%2F174%2Croot%2F137%2Croot%2F137%2F147%2Croot%2F56%2F57%2Croot%2F56%2F57%2F58%2Croot%2F1%2Croot%2F1%2F6%2Croot%2F1%2F2%2Croot%2F201%2Croot%2F201%2F213%2F215%2Croot%2F201%2F217%2Croot%2F201%2F207%2Croot%2F201%2F207%2F209%2Croot%2F217%2F242%2Croot%2F217%2F247%2Croot%2F217%2F247%2F249%2Croot%2F217%2F237%2Croot%2F217%2F223%2Croot%2F212'
sessionid 'ncuohjwxb4kfbo7pgryv9s0b9cnwxxmp'
META
Variable Value
wsgi.run_once False
wsgi.version (1, 0)
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
REMOTE_PORT '55015'
SERVER_NAME 'localhost'
HTTP_ACCEPT '*/*'
HTTPS ''
wsgi.url_scheme 'http'
SERVER_ADDR '192.168.168.45'
REDIRECT_STATUS '200'
wsgi.multiprocess False
HTTP_CONNECTION 'keep-alive'
REQUEST_METHOD 'GET'
SERVER_PORT '80'
REMOTE_ADDR '192.168.168.155'
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x8142e2ed0>
HTTP_ACCEPT_ENCODING 'gzip, deflate, sdch'
wsgi.input <flup.server.fcgi_base.InputStream object at 0x8142e2590>
SCRIPT_NAME u''
HTTP_USER_AGENT 'Mozilla/5.0 (Windows NT 6.3; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/48.0.2564.97 Safari/537.36'
HTTP_REFERER 'http://192.168.1.45/'
SERVER_SOFTWARE 'nginx/1.6.2'
HTTP_COOKIE 'sessionid=ncuohjwxb4kfbo7pgryv9s0b9cnwxxmp; fntreeSaveStateCookie=root%2Croot%2F188%2Croot%2F191%2F197%2F199%2Croot%2F191%2F207%2Croot%2F132%2Croot%2F38%2Croot%2F189%2Croot%2F191%2Croot%2F195%2Croot%2F193%2Croot%2F55%2Croot%2F55%2F56%2Croot%2F55%2F56%2F57%2Croot%2F55%2F56%2F57%2F58%2Croot%2F55%2F56%2F57%2F58%2F83%2Croot%2F55%2F56%2F57%2F58%2F87%2Croot%2F174%2Croot%2F137%2Croot%2F137%2F147%2Croot%2F56%2F57%2Croot%2F56%2F57%2F58%2Croot%2F1%2Croot%2F1%2F6%2Croot%2F1%2F2%2Croot%2F201%2Croot%2F201%2F213%2F215%2Croot%2F201%2F217%2Croot%2F201%2F207%2Croot%2F201%2F207%2F209%2Croot%2F217%2F242%2Croot%2F217%2F247%2Croot%2F217%2F247%2F249%2Croot%2F217%2F237%2Croot%2F217%2F223%2Croot%2F212; csrftoken=4p0bY7s1O93rHu0iazklrjY2uL6ieEaE'
HTTP_CONTENT_TYPE 'application/x-www-form-urlencoded'
HTTP_ACCEPT_LANGUAGE 'en-US,en;q=0.8'
DOCUMENT_URI '/system/info/'
wsgi.multithread True
HTTP_HOST '192.168.1.45'
PATH_INFO u'/system/info/'
REQUEST_URI '/system/info/?dojo.preventCache=1454164658342'
HTTP_X_REQUESTED_WITH 'XMLHttpRequest'
SERVER_PROTOCOL 'HTTP/1.1'
QUERY_STRING 'dojo.preventCache=1454164658342'
CSRF_COOKIE u'4p0bY7s1O93rHu0iazklrjY2uL6ieEaE'
CONTENT_LENGTH ''
GATEWAY_INTERFACE 'CGI/1.1'
Any idea why that would be happening?
Thanks,
Rich
RichTJ99
[root@freenas] /mnt/Pool/Storage# mv /mnt/Pool/Storage/data /* /mnt/Temp2tb/raid
mv: /bin/cp /boot /mnt/Temp2tb/raidz/boot: exec failed
mv: /bin/cp /cfg /mnt/Temp2tb/raidz/cfg: exec failed
mv: /bin/cp /conf /mnt/Temp2tb/raidz/conf: exec failed
mv: rmdir /mnt/Temp2tb/raidz/data: Directory not empty
mv: cannot rename a mount point
mv: /bin/cp /lib /mnt/Temp2tb/raidz/lib: exec failed
mv: /bin/cp /libexec /mnt/Temp2tb/raidz/libexec: exec failed
mv: /bin/cp /media /mnt/Temp2tb/raidz/media: exec failed
mv: /bin/cp /nonexistent /mnt/Temp2tb/raidz/nonexistent: exec failed
mv: /bin/cp /proc /mnt/Temp2tb/raidz/proc: exec failed
mv: /bin/cp /rescue /mnt/Temp2tb/raidz/rescue: exec failed
mv: /bin/cp /root /mnt/Temp2tb/raidz/root: exec failed
mv: /bin/cp /sbin /mnt/Temp2tb/raidz/sbin: exec failed
mv: /bin/cp /tmp /mnt/Temp2tb/raidz/tmp: exec failed
mv: rmdir /mnt/Temp2tb/raidz/usr: Directory not empty
rsquared
If that's the exact command you typed, you've got and extra space in there before the /*. You've told your system to move the /mnt/Pool/Storage/data folder AND everything in the root folder to your presumably temp pool.
All those errors are occurring because you have moved system files off of the boot device and onto your pool. At this point your only option is probably to reinstall.
RichTJ99
Lol! Typos!
So is the data OK? I dont mind a reinstall.
rsquared
You can remount your pools after a reinstall. The data should hopefully all be there somewhere, but where exactly it is, who knows.
You mentioned in your first post that even basic things like ls weren't working. This was because you had moved the system files off of the boot drive and onto your pool. Depending on what got moved in what order, this also means that things could have gone badly in the middle of the mv to the temp pool once some of those system executables were unavailable...
RichTJ99
Hmm, when I looked at the Pool storage it was empty so I guess it got moved? I have most of the data backed up so I am not overly concerned (yet).
To confirm (for future):
The command should not be this:
mv /mnt/Pool/Storage# mv /mnt/Pool/Storage/data /* /mnt/Temp2tb/raid
It should be this:
mv /mnt/Pool/Storage# mv /mnt/Pool/Storage/data/* /mnt/Temp2tb/raid
This would have moved everything in the data folder to the raid folder?
If I want to be safe next time & do a copy would the command be?
cp -R /mnt/Pool/Storage# mv /mnt/Pool/Storage/data/* /mnt/Temp2tb/raid
Also, the boot device is the two USB sticks I am using - the space /* said to get everything in /data & everything on the usb sticks?
RichTJ99
Annnnd very lucky for me I had an extra USB (disk 3) as a spare which had my config on it. I did an install/upgrade and it seems to be back up. I am doing data comparison now.
How do I backup my config - not something I did before.
gpsguy
Active Member
From the documentation -
Backup the FreeNAS® configuration in System→General →Save Config.
Many of us use a cron job to backup the configuration automatically. Search the forum for suggestions.
RichTJ99
Where do you back up the config to? I imagine the config file is small.
rsquared
It should be this:
Close, but you've copied and pasted a little too much. Everything before the # is part of the command prompt, so you would be looking at one of the following:
cp -R /mnt/Pool/Storage/data/* /mnt/Temp2tb/raid
The thing to remember is that most unix file manipulation commands a single destination argument (whatever is listed last) but multiple input arguments (everything else before that), with a space being the delimiter between those arguments. So again you're close, but not quite there. Your command said to get everything in your data dataset, as well as everything on your system (not just on the usb sticks) and move it to your temp pool. The difference being it would also have grabbed anything on any pools and moved them too.
gpsguy
Active Member
If you do it manually, via the webGUI, then you probably saved it on Windows, Mac, Linux, ... whereever.
With my cron job, I just copy it to my storage pool and append a date in the filename.
I can pull them off or cleanup the directory, via CIFS. In the event that I didn't have a recent one stored offline and my boot device died, I could reinstall FreeNAS, get to the directory, grab one off the server, and restore the "old" configuration. The files are tiny.
RichTJ99
Fortunately my data looks good. I even decided to pull an old snapshot (data stays pretty much the same) from a few days ago & am copying things over properly this time :).
Command line is fun - i feel techy - at least until I break something.
RichTJ99
Last question - is there a way to see the 'status' of the cp, mv, or rm within the command line? So I can figure when the data transfer is going to end, or if it is stuck, etc?
Bidule0hm
Server Electronics Sorcerer
Add the -v option, it's not a progress bar but you'll see what files it's copying/moving/deleting and as it does it by alphabetical order you can estimate yourself where it is ;)
RichTJ99
Thanks - that is great!
