MartynW
- Feb 23, 2014
As I understand it FreeNAS is now sort of supported under ESXi as long as you use pass-through.
I currently have FreeNAS running on a Super-micro X10SL7-F system flashed to IT.
I would like to ideally move this to a system running ESXi with FreeNAS running in a VM supplying storage to the base system and have noted this guy has a blog on how-to using similar hardware.
If I follow his instructions am I able to move my 1 encrypted zVOL (RAIDZ2) to the new FreeNAS VM?
If I restore my config, will my plex jail be preserved?
What about my iSCSI extents?
My plan is to use a new USB boot device, add a new HDD to the on-board SATA (not LSI) to install the VM. This way if it doesn't work, my original FreeNAS setup will be still available and unharmed?
What pitfalls can I look out for?
