mount points between jails
mewhalen
I have FreeNAS 9.2 with two jails installed,
Jail 1 - owncloud plugin
Jail2 - standard jail with Syncrify client installed for backups.
I use the Syncrify client to back up my FreeNAS to a Syncrify server, which works fine. I would like to also use the Syncrify client to back up the owncloud data.
Is this possible?
fracai
Sure. Your jails are probably structured something like:
tank/jails/owncloud
tank/jails/syncrify
Just mount the owncloud jail directory inside the syncrify jail using "Add Storage". Is your owncloud data actually in the owncloud jail though? Or did you mount the data from somewhere else in your pool? If the actual location is somewhere else, it'd be better to mount it from there.
