Most of my jails fail to start
rb106098
I'm running truenas core TrueNAS-12.0-U7
Since I enabled HW encoding with Plex I've been having remote playback issues. Finally I turn HW off and it seems to fix my issues.
I tried to restart plex today because I again was having playback issues. The Jail would not restart, stop even when I tried to --force stop through the CLI
I decided to just restart my entire server. after the reboot none of my iocage auto started. When I go to start any of my iocages I get the following error
Error: [EFAULT] + Starting services FAILED ERROR: [b''] Refusing to start <jailname>
I've search for the last 3 hours and I'm not finding an exact match for this error. I'm starting to think I may need to delete the iocage dataset and start fresh? ugh
Any help/advice would be greatly appreciated.
Note: As a test I chose 1 iocage and tried rollback to yesterday (root and default snapshots). This did not solve my issue.
rb106098
Here's what I'm seeing when I try to start the the iocage
root@freenas:~ # iocage start plex-plexpass
No default gateway found for ipv6.
* Starting plex-plexpass
+ Started OK
+ Using devfs_ruleset: 1002 (iocage generated default)
ELF interpreter /libexec/ld-elf.so.1 not found, error 2
+ Configuring VNET OK
+ Using IP options: vnet
ERROR:
[b'']
Refusing to start plex-plexpass: exec_start failed
