aleatorvb
- Nov 14, 2012
You can monitor remote disk with nagios over ssh.
Ssh script to be copied on the freenas server, I used /mnt/pool1/users/nagios/check_diskfree.sh
Configure nagios to monitor
- using check_diskfree.sh script
- dataset /mnt/pool1
- warning at 90%, critical at 95%
Works like a charm.
Attention!
This requires having the nagios user being able to ssh to the freenas_host_ip_address with passwordless login using ssh-keys.
Create a nagios user on freenas and allow it to remotely login via ssh.
Also select a home folder for it.
Create public/private key pair
..and then copy the key to freenas (using ubuntu as example here)
.. now we're back on nagios server. To test passwordless login type
case $1 in
--help | -h )
echo "Usage: check_diskfree [dev] [warn] [crit]"
echo " [warn] and [crit] as int"
echo " Example: check_diskfree hda1 70 90"
exit 3
esac
if [ ! "$1" -o ! "$2" -o ! "$3" ]; then
echo "Unknown: Options missing"
exit 3
fi
used=`df /$1 | tail -n1 | sed -r 's/\ +/\ /g' | cut -d \ -f3`
free=`df /$1 | tail -n1 | sed -r 's/\ +/\ /g' | cut -d \ -f4`
full=`echo $(($used+$free))`
percent=`echo $((( $free * 100 ) / $full))`
warn=`echo $((( $full * $2 ) / 100 ))`
crit=`echo $((( $full * $3 ) / 100 ))`
if [ "$warn" -gt "$crit" -o "$warn" -eq "$crit" ]; then
echo "Unknown: [crit] must be larger than [warn]"
exit 3
fi
if [ "$used" -lt "$warn" -o "$used" -eq "$warn" ]; then
echo "OK. Free Space: `df -h /$1 | tail -n1 | sed -r 's/\ +/\ /g' | cut -d \ -f4`B, $percent%"
exit 0
elif [ "$used" -gt "$warn" -a "$used" -lt "$crit" ]; then
echo "Warning. Free Space: `df -h /$1 | tail -n1 | sed -r 's/\ +/\ /g' | cut -d \ -f4`B, $percent%"
exit 1
elif [ "$used" -gt "$crit" ]; then
echo "Critical. Free Space: `df -h /$1 | tail -n1 | sed -r 's/\ +/\ /g' | cut -d \ -f4`B, $percent%"
exit 2
else
echo "Unknown"
exit 3
fi
define service{
use local-service
host_name freenas_host_name
service_description Disk Usage
check_command check_by_ssh!22!/mnt/pool1/users/nagios/check_diskfree.sh!mnt/pool1!90!95$
max_check_attempts 3
check_interval 5
retry_interval 3
check_period 24x7
Works like a charm.
Attention!
# login to nagios server with the nagios user cd ~ mkdir .ssh chmod -R 700 .ssh cd .ssh ssh-keygen -t rsa # do not enter any password if you want passwordless login
ssh-copy-id freenas_host_ip #enter password exit exit
ssh freenas_host_ip
